First post, by tereg
Ola comrades
"V got interesting Deutsche XT clone of 8088 (Schneider Euro XT)
Trying to install in subj.VGA-card in 8-bit slot mode fcrse .
There is a problem - it randomly starts system in color or grayscale mode. Don't know why....
MB have no real switches, but presoldered (I tried some around video chip with knife and soldering - no effect)
Any ideas?
Reply 1 of 8, by derSammler
Try a different monitor. Back then, one ID pin was used for mono, but that one is used for DDC these days. You could also modify the VGA cable.
Reply 2 of 8, by lazibayer
Sounds like a job for Samwell!
Reply 3 of 8, by tereg
How do you think I can get older crt-vga monitor ))) it all on junkyard now.
I read a lot about this pin problem - do you have any ideas which pin is needed.
(As i know there is 3 - like 4, 11 and 12)
Reply 4 of 8, by derSammler
Pin 12. If connected to GND, the graphics card will display color; if not connected (open), the graphics card will display mono.
It's probably easiest to solder a GND connection to pin 12 directly on the VGA card. Since the pins are exposed on the back side of the card, this takes maybe one minute. 😉
Reply 5 of 8, by tereg
schss!
It doesn't work
two of 3 id pins is totally in air. pin 12 available to try only. Doesn't work too (started artifacts...)
Any another ideas?
Maybe somebody have ehhhh manual for this wunderwaffe?
Any dos (not more 720kb) utility that can test video modes?
Reply 6 of 8, by Jo22
If this was about a more recent computer, I would maybe have recommended installing a V2*.
(*3dfX Voodoo 2, of course.)
Edit: Did you try MODE COLOR or MODE MONO in DOS ?
Edit: I meant MODE CO40 / MODE CO80 and MODE MONO (MODE BW40 / MODE BW80) , of course.
The commands are described here: http://www.easydos.com/mode.html
Reply 8 of 8, by tereg
Guyz, it seems I found problem.
Just now (cause didn't find way to disassembling CRT monitor - no one screw... f..ng compaq capitalistic bastards) I vandalized monitor's vga d-sub.
I cut off pin 12 (twelve mthfckr) to devils hell.
And FFFFFFFFFF...ck! It works! Works Works Works!
AAAAAAAA
It seems works.
Anyway thanks for attention.
