First post, by pjotr646
Hi, how set dip switch on this vlb card. Thanks
Thanks for help
I know this card well... it worked on some motherboards I tried it on but not on others depending on the front side bus clock i.e. 33MHz and 40MHz.
The resolve the issue, I usually toggled jumper JP5 and it would boot fine.
This was not the only card I found to decide when to work or not depending on the bus frequency.
I have this card. What drivers should I use? I tried the once for Miro Crystal 8s here: http://cd.textfil.es/cica/cica9603/disk2/disc … eo/00_index.htm
I can install the drivers, but when I start the program to set the monitors resolution and refresh rate I get error message.
youtube.com/uncleawesome
