Reply 480 of 1528, by SquallStrife
- l33t
wrote:Also when it comes to VGA2HDMIPro the quality just wasn't good imo, noticeable ringing around reds and I'm pretty sure it reduces colorspace. Though I was more annoyed with slow switching even when it's not resolution but merely refresh rate, some games did that, like automap in Descent and Jazz Jackrabbit.
Those are the trade-offs, yep. RGB 16-235 and mode switching time, hence why I only use it when I absolutely have to.
That said, my use case is streaming through OBS, not creating accurate captures for archival, so the reduced RGB space isn't as big of an issue for me.
It's definitely a consideration though, depending on what you want to accomplish.
