Which Voodoo card to buy ?
First post, by Intel486dx33
Hello, I am NEW to gaming.
Some cards I have owned
Nvidia Banshee
Riva TNT
Nvidia graphics cards
Matrox millennium
Matrox G400/450 dual head
I want to how to setup Voodoo card with What other card ?
I have an Nvidia fx5500 PCI I can use ?
Or should I use an AGP card ?
Or some other card ?
Which is bests and Which Voodoo card to buy?
The Voodoo-5 is to expensive so I am looking for a card that is fairly available and not to expensive.
Reply 1 of 34, by Tree Wyrm
If you want compatibility with DOS Glide titles then either Voodoo1 or Voodoo2. If you don't care about that and stick to Windows titles then Voodoo3 is a good choice and has no need for 2D card. AGP or PCI doesn't particularly matter, whichever works for your build.
Also... Nvidia Banshee?! There was Voodoo Banshee though.
Reply 2 of 34, by Intel486dx33
Which version of Voodoo is the Voodoo Banshee ?
Reply 3 of 34, by jheronimus
Really depends on the games that you want to play. There is not a whole lot of difference between different Voodoos in terms of features/capabilities — it's really more about performance. So it simply boils down to what year were your favourite games released.
MR BIOS catalog
Unicore catalog
Reply 4 of 34, by Tree Wyrm
Banshee is a cut-down version of Voodoo2, missing second TMU but having a relatively good 2D so it didn't need a separate card.
Reply 5 of 34, by lvader
I think the Voodoo 3 is a good first voodoo to get, combined 2D and 3D, good video output quality. Pleanty of availablillty, prices aren’t too stupid.
Reply 6 of 34, by candle_86
Banshee is also sometimes faster than voodoo 2
Reply 7 of 34, by mwdmeyer
I agree V3 is a great first 3dfx video card. Easy to use (single card), good speed and reliable. Goods idea to have a fan nearby as they run warm.
I'd recommend a PCI version if you can get one as it is more flexible.
Reply 8 of 34, by KT7AGuy
As others have already mentioned: Voodoo 3 3000. It is the cheapest, easiest, and simplest option.
Get the AGP version. It performs slightly better than the PCI version and is much less expensive.
Reply 10 of 34, by KCompRoom2000
I thought the AGP Voodoo 3s had no advantages over their PCI counterparts due to not using any AGP exclusive features. 😕
Reply 11 of 34, by dionb
No special AGP features, but the AGP port still runs twice as fast as a regular 33MHz PCI bus. They take advantage of that. However bus throughput is rarely the bottleneck, so the difference isn't large, even on a Voodoo5, and is negligible on a Voodoo3.
Reply 12 of 34, by KCompRoom2000
Right, I almost forgot about that. Still, there's nothing wrong with an AGP Voodoo 3, it's just that the PCI models offer versatility over the AGP counterparts due to the AGP model only being 3.3V compatible and the fact that AGP was still not that common back then.
Reply 13 of 34, by Fusion
I love my V3 PCI, glad it ended up not being the AGP variant.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 14 of 34, by leileilol
Tree Wyrm wrote:
Banshee is a cut-down version of Voodoo2.
It's more of a VGA'd souped up version of the original Voodoo Graphics, done right... Most of V2's additional registers are not found in the Banshee or the rest of the Voodoo lineup.
Reply 15 of 34, by KT7AGuy
Interesting. I didn't know this. Will a Banshee work with static-link DOS games like Archimedean Dynasty and EF2000?
Reply 16 of 34, by candle_86
If it works on the voodoo 2 it works on the banshee. Fun fact a banshee is clocked higher so in single texturing games where the Voodoo 2's extra TMU on its one pipeline means nothing the banshee will outscore a Voodoo 2.
Banshee is more like Voodoo 3 light
Reply 17 of 34, by oohms
I much prefer a Banshee or Voodoo 3 to using the Voodoo 2. I just can't be bothered with the extra drivers and diminished VGA signal (or using a KVM) and limited resolution that using a Voodoo 2 entails
Performance wise a Banshee is roughly as fast as a single Voodoo 2 and a Voodoo 3 is about as fast as Voodoo 2 SLI
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 18 of 34, by tayyare
But not as cool! 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 19 of 34, by candle_86
tayyare wrote:
But not as cool! 🤣
Yes it is, that's why banshee and 3 shipped with heatsinks 😜
