My 3DMark03 Mega Thread
Reply 41 of 81, by agent_x007
Windows 98 SE :
473.35 KiB
Windows 2000 :
242.78 KiB
Windows 7 x64 SP1 :
1.26 MiB
Not exact settings on all three, but I had to take advantage of that 32-bit stability 😀
Reply 42 of 81, by Imperious
Intel Celeron Northwood @ 3357mhz, HD3850 AGP@810-954
Reply 43 of 81, by rod
System: Dell OptiPlex 745 Desktop
OS: Windows XP x64 SP2
CPU: Intel Xeon 3070
Memory: 8GB (4 X 2GB) DDR2-800 CL6 SDRAM
GPU: AMD HD7750 1GB 128-Bit GDDR5
Reply 45 of 81, by rod
System: ASRock 4CoreDual-SATA2
OS: Windows Embedded 8.1 Industry Pro x86
CPU: Intel Xeon X3230
Memory: 4GB (2 X 2GB) DDR2-667 @ 533 CL4 SDRAM
GPU: ATI Radeon HD3850 512MB 256-Bit GDDR3
    614.56 KiB
Reply 46 of 81, by Almoststew1990
Benchmark all the things!! (that probably shouldn't be benchmarked!)
ASUS EEE PC netbook from... 2008 maybe?
(The screen is 1024*600, so the bottom bar gets cut off... you can scroll up and down in any full screen application that is *768 🤣 )
Linx 1010B Tablet / netbook thing from 2015
What is more impressive is that the tablet doesn't have a fan or anything, and is charged up by a standard 2amp usb adapter thing. The netbook has a proper fan and power brick and everything...
Reply 48 of 81, by Baoran
When I saw the previous post, I just wanted to see how much bottleneck the cpu would be while having the same cpu and faster graphics card. So I ran the 3dmark03 with my main desktop pc as well to see the difference.
126.32 KiB
Reply 49 of 81, by Almoststew1990
Good to know my cpu is not holding my back then*! And that's at stock speeds
*in a 15 year old synthetic benchmark
Reply 50 of 81, by Baoran
Yeah, cpu is at stock clock speed. The gpu is asus strix version of 1080ti, so it is overclocked a bit. I have 16Gb kit of 2400Mhz ddr3 and it can't handle at 2400Mhz if I overclock the cpu and I get blue screen with any cpu overclock.
Reply 51 of 81, by Standard Def Steve
Hey, someone finally beat my score on the first page. Very cool! 😀
Reply 52 of 81, by Baoran
This thread probably isn't meant for testing modern pcs though. PCs are getting faster really slowly nowadays though. Like my 5 years old pc with 4770k cpu still works fine with modern games and after I upgraded the gpu to 1080ti last year, I probably don't have build a new pc before 2020. I used to have to build a new pc every 3 years. If anyone happens to have a faster cpu, it would be interesting to see how much of a bottleneck 4770k is with 1080ti in 3dmark03.
Reply 53 of 81, by MrMateczko
Not many laptops can fully run 3DMark03 on Windows 98SE, my newly aquired IBM ThinkPad T42p is one of them 😜
Test 1 score seems very low though 😒
Reply 54 of 81, by Standard Def Steve
Haswell's HD4600 integrated graphics in a Lenovo ThinkCentre. I'm actually very impressed with the performance! Keep in mind this is using cheap CL11 DDR3-1600; it would probably do much better with DDR3-2400, but I was too lazy to borrow that RAM from my main system.
Reply 56 of 81, by Shagittarius
http://www.3dmark.com/3dm03/6539830
186.54 KiB
i9900k w/ 2080Ti
If I put a little effort in I could probably push it to 200k.
Reply 58 of 81, by Carlos S. M.
when you try 3DMark03 on a Cyrix 6x86 PR166+...
116.44 KiB
