First post, by Grzyb
I'm looking for some program to test various SVGA cards - mostly ISA, VLB, and early PCI ones.
The program must run under pure DOS.
Ideally, I want something like Checkit 3.0, ie. test video memory, and display some test patterns in all the modes. And small enough to fit on a 1.44MB diskette along with DOS boot files.
Checkit is OK for MDA, Hercules, CGA, EGA, VGA, but it doesn't support SVGA - so it only tests 256 KB of RAM.
So, any advice?
Reply 1 of 6, by Jo22
On DOS ? Dr. Hardware ?
Windows 3.x/2.x..
Re: Best PCI VGA card for Windows 3.11 performance?
Reply 2 of 6, by Grzyb
Looks like just a sysinfo program, I can't see any options to test video RAM integrity, or enter various video modes.
VBETEST (a part of UniVBE) seems OK for testing various video modes, but I can't see it doing any video RAM tests.
Reply 3 of 6, by beastlike
there's whatvga.exe, which can be found here: https://github.com/achernya/iap-6.828-website … hardware/vgadoc
and here https://pdos.csail.mit.edu/6.828/2018/reading … ardware/vgadoc/
27.04 KiB
this one is useful because it'll show you what modes you have available, and will let you do drawing tests in each mode.
23.4 KiB
I am not sure if it does video RAM tests, however if you look there's a util called dmpmem.exe which creates 2 files; both have .ROM extension, one is binary, the other is this text:
INT 10h = F000:1300
INT 6Dh = F000:1060
State Table = C000:2E8F
FNT0 = C000:0500
FNT1 = C000:1700
FNT2 = C000:0900
FNT3 = C000:0100
FNT4 = C000:0500
FNT5 = C000:2710
FNT6 = C000:1700
FNT7 = C000:2710
more info on this in whatvga.doc
there's also this one I remember from back in the day, this is the source: http://www.vbforums.com/attachment.php?attach … 39&d=1082326758
this compiles to an executable I have called vesabase.exe which I have used, but can't find anywhere on the internet
11.65 KiB
Reply 4 of 6, by Grzyb
The above don't seem to perform video memory test, and this is the most important feature I'm looking for.
I want something like MemTest86 (comprehensive testing using various patterns), but for video RAM, rather than system RAM.
Reply 5 of 6, by zyga64
X-VESA can test all video memory available.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 6 of 6, by Grzyb
X-VESA seems interesting indeed, but there's one problem - it uses a non-standard 90x30 text mode for menus, and I've already found one card where that mode fails to work correctly.
So I'm still looking...
