First post, by ShadowofBob
As I've done quite a bit of research into this following successfully repairing my 5500 I thought I'd post my cooling/fan replacement and upgrade findings here and let others contribute as well.
Stock Fan/Cooling replacements/fixes
The stock AAVID cooler/fan combo seems to work adequately, but by this time in the cards life most have bad fan bearings. Finding the fan on it's own(MODEL 1447122) in new shape is near impossible so most of the time this is not a viable solution.
  • Currently there is NOS of the fan and heatsink on ebay for $8.95!
  • A 2 wire version of the fan is on ebay as well. Has the same part number and I suspect the original 3pin pigtail could be soldered right on the board of these fans as they have the same part numbers. The seller says it is seller refurbished, so take that with a grain of salt. Might be worth inquiring for more info if you are interested in this as a replacement.
  • One fix people seem to suggest doing on the German VoodooAlert forums is to replace the bearing itself. Sourcing this seems like more time/cost than the fan itself is worth, but if it's something that interests you or you want to rebuild/grease the fan follow the guide in the link below.
    https://www.voodooalert.de/board/forum/index. … r-lagerwechsel/
  • A decent aftermarket replacement is the SUNON KD0504PEB3. It's 5V and the same 7mm thickness, but has no signal wire. There are conflicting reports on if the Voodoo card even uses the RPM signal if it is available, but general consensus is that it's okay to run a fan without. If you do get this fan (or any other non original) you'll need to affix a JST 3pin 2.0mm spacing connector to have it plug and play on the 5500. This can be done with simple soldering to the old fan plugs or by tracking down the pins and plastic JST shell and crimping to the new fan wires.
  • If you have the space for a full 10mm thick fan and/or don't mind having a brown fan mounted the Noctua NF A4x10 5V is probably the quietest replacement.
    https://extreme.pcgameshardware.de/casemods/4 … fx-casemod.html
Aftermarket coolers
Say you want to remove the factory heatsinks because thermal paste or modern thermal adhesive tape probably will conduct heat better. Follow the video below for the best method to remove the heatsink. I found you didn't need to put that much freeze spray on to adequately chill the chips. You can also use Compressed Air cans if you hold them upside down for the same effect of freezing.
https://www.youtube.com/watch?v=5hB4jOCHLHc
Once you have the coolers off you'll need to begin the arduous process of removing any residual glue that did not come up w/ the heatsink. Isopropyl Alcohol and a qtip/rag are you best bet. It'll take time and lots of elbow grease to get all the hardened glue off.
The next thing to address is that most aftermarket coolers use a hole spacing of 55mm or 59mm. The Voodoo 5 5500 has a non-standard spacing of 57mm. You can usually file out the holes a bit to allow push pins to fit or if your cooler has rubber pins you can just pull those through and the flex will work fine with the 2mm difference.
Titan TTC-CSC03E
Vantec CCB-A1C or CCB-A1A
Another set of coolers that most people work well is the CCB-A1C and the CCB-A1A.
  • The CCB-A1C is copper and has ball bearing fans.
  • The CCB-A1A is red anodized aluminum and has sleeve bearing fans.
  • Both fit on the Voodoo 5 5500 w/ out and spacing issues from the capacitors being nearby as shown in the 3Dfxzone.it thread
  • https://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=3068
  • The fans can be run at 12v or 5v according to posters.
Titan CUV1AB/ CUV2AB/CUV4AB
Reply 1 of 8, by bofh.fromhell
Matrox G400 MAX has the same 5v AAVID problem (and solutions).
I find that https://noctua.at/en/products/fan/nf-a4x20-5v with its higher static pressure and airflow is also a good replacement if you can sacrifice a slot.
Neither of the noctuas are noisy despite the 4500-5000 r.p.m's.
Reply 2 of 8, by aaronkatrini
Yeah those AAVID fans on the G400 max are always making such noise...
BTW I'm also looking for a stock AAVID fan for my V4 as it was discussed in another thread.
Thanks for the link for the USA eBay seller, it seems to be the one... But in the description it says 37x37... Is it the same as the 40x40 and the seller did a mistake?
The prise is good (~8euro), but ~18 euro shipping to Italy... Dang it!
I'm really hesitant!!!
Reply 3 of 8, by Doornkaat
aaronkatrini wrote on 2020-02-13, 12:59:
Yeah those AAVID fans on the G400 max are always making such noise... BTW I'm also looking for a stock AAVID fan for my V4 as i […]
The heatsink is slightly smaller than the fan. AAVID lists fan measurements, the ebay link lists heatsink measurements.
Reply 4 of 8, by aaronkatrini
Thank you again @Doornkaat !
I ordered one, it should arrive by the end of the month ... 😁
Reply 5 of 8, by Weebob
Great thread ShadowofBob, ta
Reply 6 of 8, by murrayman
Resurrecting this thread to throw in my $0.02 since some of these products were showing out of stock for the past few months:
I just bought two of these off Amazon, and they’re a good replacement. The retaining pegs don’t quite line up - the heatsinks is slightly wider diagonally than the holes in the PCB - but I had no difficulty getting the pegs to go in at an angle without any concerning amount of pressure. The heatsink’s plate is flat enough to make decently even pressure against the chips. Paired mine up with some Noctua NF-A4x10 5V using the supplied adapters and ignoring the third wire, as the fans that the HSF came with were 12V and one was busted. Works like a charm, if not the prettiest thing in the world.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 8 of 8, by Delerium
I bought the Titan TTC-CSC03E and they do not fit very well.
