First post, by waterbeesje
- Oldbie
Last week I bought a VLB graphics card, with unknown chipset, untested and even by picture it was unclear what it was.
Got it along with the 486 boards and a DX50 CPU (those are working already, but need more testing befir I post).
Now this graphics card turned out to be based on the Avance Logic Inc ALG2228A chip. Everything looked normal, no caps broken off but with a little bit of dirt on the VLB side of the bus connectors.
After cleaning I put it on a VLB board with a Cyrix DX/2 and 8 MB Ram which I know that is working with a Trident To GUI9420.
Screen: rubbish.
Took it out and took another look at the card with as magnifying glass and it seems there has been a bad repair at the graphics chip.
So, experts, Is this fixable?
If yes:
There now is 1MB memory available, in four 256kx8 chips. Will soldering four extra memory chips with the same specs add 1MB just the same way it works with "regular" socketed graphics cards?
Stuck at 10MHz...
