First post, by PC-Engineer
Is it possible to use the memory upgrade module Rev. A3 (8 chips, Samsung) on a card Rev. D4 (4 chips, IBM)?
http://www.vgamuseum.info/index.php/cpu/item/ … lb-s3-vision968
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 1 of 21, by mpe
Not sure if it works, but the 4 chip IBM is EDO VRAM while the 8 chip is FPM VRAM part. So even if it works it likely won't be optimal. I'd try to get a matching upgrade if possible. But these parts are rare...
Blog|NexGen 586|S4
Reply 2 of 21, by The Serpent Rider
Pretty much impossible to find. Although it's not all that useful for 486 machine. And you still can use maximum 1600x1200 resolution even with 2 Mb, but just in 256 colors.
Reply 3 of 21, by PC-Engineer
Ok, seems that i have to go on with searching.
It’s not important for using. Had upgraded my Socket3 VLB system with it, and i am very happy so far. I need the upgrade only for the quantum which makes me feel it’s perfect. The Diamond S3 968 VLB is imo the best (fastest card) card for VLB, especially with 4MB (ok, maybe there is a legendary, unobtainable Elsa W2000 Pro/X with 8MB - but not as fast as the diamond in DOS apps) Hope the memory upgrade is easier to obtain than the card itself 😉
Reply 6 of 21, by Anonymous Coward
Until I see some proof, I'm going to say that it's more wishful thinking than anything. I could possibly see an 8MB card existing if it was one of those dual display types though.
Reply 7 of 21, by The Serpent Rider
I don't see how 8 Mb 968 even would be possible. It has only 175 Mhz or 220 Mhz DAC, so you're limited to 1600x1200 in 16-bit color at best and anything above 4 Mb is pointless.
Reply 9 of 21, by pshipkov
The pci version is pretty good in windows (still quite slower than the mga), but is dismal in dos.
Or at least thats what I see here.
Is the view different from your tower ?
retro bits and bytes
Reply 10 of 21, by The Serpent Rider
S3 Vision 968 has more than enough horse power for any 486.
Reply 11 of 21, by pshipkov
You have a point.
Let me rephrase - s3 968 seems to 10% to 30% slower in DOS than many common video cards from that time period.
Still, pretty ok in most cases for 486dx# class machine.
Better ? 😁
Reply 12 of 21, by The Serpent Rider
It's slower only in VGA/X mode, but you'll barely would see even 10% difference with any 486, even if it's overclocking 200Mhz wonder. But when it comes to VESA modes, it's one the best PCI cards out there.
Reply 13 of 21, by pshipkov
Great information. Thanks for taking the time to put it together.
Here is my thinking about S3 968 and 486.
On a 486 class machine, considering a decent video card, when it comes down to non-accelerated DOS graphics - performance is hard CPU bound. As a result we are largely stuck in VGA modes. The 486 hardware does not have the strength for more.
For instance: even the best 486 rig can barely deliver ~20 FPS in Quake1 320x240, or 60 FPS in Doom, or another-low-number FPS in Duke Nukem.
Of course, there are some DOS apps/games that provide their own accelerated video drivers, but these are rare exceptions.
So even S3 968 does very well in high-resolution video modes, this is a minor factor for 486+DOS graphics. In fact it lags there behind most decent video cards from that time.
Silicon+driver accelerated Windows GUI partially decouples us from the CPU bottleneck - that's where 968 starts to shine.
Reply 14 of 21, by The Serpent Rider
VESA modes actually include 320x200, 320x400 and other low res options. 320x200 VESA is faster than 320x200 VGA even on 486.
Reply 15 of 21, by kixs
pshipkov wrote on 2020-08-24, 20:08:
Great information. Thanks for taking the time to put it together. […]
VLB version tops DOS and Windows benchmarks on a AMD 5x86-133. There are only small differences between better cards in DOS. While in Windows difference is big.
What cards/chipsets do you compare the S3 968 to? S3 Vision family is a 1994 date chipset.
Reply 18 of 21, by The Serpent Rider
There is no loss of speed under both DOS and Windows.
Try C&C Tiberian Sun, there should noticeable performance nosedive at 800x600.
Reply 19 of 21, by PC-Engineer
I tested with several graphics benchmarks in Win95 @ 800x600x32bit. There seems to be no physical Impact in memory Performance. Why should games lead to a different behavior of the graphics memory because of an memory upgrade?
In general I think 800x600 gaming is to much for a (Socket 3) VLB system.
How exactly did you make this experience? With which graphics cards and graphics memory combination?
