Reply 80 of 178, by darry
The Serpent Rider wrote on 2020-05-05, 10:15:They should be able to work with 70Hz without frame skip.
I have no doubt that that a monitor advertised as able to do 70Hz will be able to do it in a modern version ofWindows .
What is less certain is
a) if it will do 70 Hz over VGA (if it even has VGA input)
b) if an older card can be convinced to send out 70Hz to it over DVI in DOS (not sure what the EDID looks like on those over 60Hz capable monitors)
c) if Windows 9x or XP drivers for older cards will allow setting 70Hz over DVI .
d) for points b and c, if older cards are even capable of 70Hz over DVI
