Going to necro this thread because I am having some wicked issues with this T23 that I never remember experiencing in the past. I've jumped between the laptop itself and the docked experience a lot, but this go around, I've done a fresh installation. 98SE with naught but IE6 installed, Intel's chipset drivers, Crystal Audio, Battery MaxiMiser, IBM High Rate Wireless, Intel PRO/100 drivers, and I'm using a KingSpec 60GB PATA SSD and a 128GB SD card over PATA in the UltraBay 2000 hard drive caddy. Every other reboot, I may get a black screen, and the only way out is to force shutdown or three-finger salute. Upon reboot, I usually end up in 640x480x8 and have to re-install the driver. I'm at the end of my rope with this, and I'm wondering if it's the drivers from IBM. I used this specifically, I'm gonna try that one linked above. Alternatively, there's mention of modded Chrome drivers that may make Metal work correctly? IIRC, Metal worked fine when my GPU worked correctly in UT, but I can't test those drivers anyway. That WeTransfer site plain doesn't work for me. I've tried two different browsers and now have tried on my phone to no avail.
Does anyone know of a reason why this driver continually fails? I recall when there was still some form of the S3 site alive, I used an updated version from that, or maybe it was just the SDR drivers over the 1014 drivers...
