3dmark99 MegaThread
Reply 240 of 415, by bloodem
cbjaust wrote on 2021-02-01, 06:47:
Yes, I see the same problem with 3DMark 99 Max on modern AMD Ryzen platforms both with AMD and nVidia video cards. No fix found though.
I made a video showing the issue: https://youtu.be/bmdhu_dl94k
Don't have that problem on my Ryzen 3600X/RTX 2070
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 241 of 415, by cbjaust
bloodem wrote on 2021-02-01, 07:01:
on Windows 10? I'm seeing the problem right now with a 3900X and a GTX 980 Ti in Windows 10. Here are some more with the same thing in Windows 7 with a 3600X:
https://hwbot.org/submission/4321563_cbjaust_ … d_4890_40_marks
https://hwbot.org/submission/4318678_cbjaust_ … d_5770_35_marks
https://hwbot.org/submission/4315558_cbjaust_ … ega_56_29_marks
Reply 242 of 415, by bloodem
Well, yeah, the latest Windows 10 version (20H2)
However, I forgot to mention that I'm using djVoodoo, so that might explain why it's working fine for me. 😀
Reply 243 of 415, by bofh.fromhell
Tested my Asus P3B-F with all my different P6 CPU's.
GC is an Asus V7100, GF2 MX 400.
Same fast memory stick with tightest memory timings in all the FSB speeds.
Made a nice CPU scaling chart in 3DMark 99 I'd say!
Reply 244 of 415, by NostalgicAslinger
AMD K6-III+ 550MHz and ELSA Victory II (3dfx Voodoo Banshee) AGP
Reply 245 of 415, by DanielChief
This is my P3:
- Supermicro P6SBA (i440BX, 100MHz FSB)
- 512 MB RAM (133@100 CL2)
- Pentium 3 700 MHz Slot-1
- Voodoo 3 3000 @ 3500 (latest official driver, vsync off)
Score: 6027, CPU score: 10843
Reply 246 of 415, by Aebtdom
I have done some benchmarking on 3DMark 99.
Here are some of the results on three different resolutions.
1024, 800 and 640.
More Grapics results wil follow in time.
Pc details in my signature.
All cards at default clock and stock official drivers.
Builds:
Xp3000+ radeon 9600XT + vd2 SLI 12MB + 512MB + SB live @ WinXP & 98 Dualboot.
AMD K6-3+ 600Mhz+ Geforce 3 Ti 500 + 3Dfx Voodoo 2 12MB SLI + Sound Blaster 32 + 128MB SDR @ msdos / win98.
Reply 247 of 415, by Aebtdom
The attachment 20200920_165034.jpg is no longer available
My voodoo 5 5500 at my system
Builds:
Reply 248 of 415, by Aebtdom
This are for now the 3Dmark 99 results . Videocards I have here at home which do work are benchmarked with the as far as I know the best available drivers.
So this is it for the time being.
Interesting to see is that the voodoo 5 5500 beats the Geforce 4 4200 at 640x480 and 800x600.
I have arranged the test results at 800x600 and all the test are with the same settings at 16bit colors.
All of them used on my AMD XP2400+ CPU with 512MB ddr333 on a Gigabyte GA-7VRXP mainboard.
Voodoo 2 cards are tested in combination with the voodoo 5, gf4 and S3 Savage 4 and the results are all well within a margin of error.
All cards were tested at stock speeds, except for the voodoo 3 3000 where clockspeeds are shown.
More complete update:
The attachment 3DMark 99 Scores .jpg is no longer available
The attachment 3DMark 99 Game1.jpg is no longer available
The attachment 3DMark 99 Game2.jpg is no longer available
Builds:
Reply 249 of 415, by sepp
I have already read in this thread that you have to switch off VSync within the use of 3Dmark99 via the driver in order to get over 60FPS in the first two tests.
First I tried it via the global settings of the NVIdia driver (setting not left to the application) and switched off VSync.
But that didn't work.
Then I created an individual profile for the 3dmark99.exe (disabling VSync).
What else can I try?
My system:
Windows 98
NVidia FX5700 @ 53.04
Reply 250 of 415, by sepp
Using RivaTuner did the trick - I forced Vsync=off via this tool and it worked 😀
Reply 251 of 415, by bloodem
tpowell.ca wrote on 2019-02-09, 14:40:
Hello. Has anyone experienced a problem where the benchmark is clearly running perfectly but you get 0fps? Oddly enough in my ca […]
Hello.
Oddly enough in my case, this only happens with a VIA C3 Nehemiah cpu, all other hardware remaining unchanged.
Same motherboard, same video card, same drivers.
C3 Ezra-T and P-III CPUs run perfect.
Can confirm the issue on VIA C3 Nehemiah. My guess is that the software makes some inaccurate assumptions in how it implements the "Intel processor CPU optimizations" (most likely referring to MMX code), and based on those assumptions (that probably give different results on a VIA C3) the FPS division calculation is wrong.
UPDATE:
Ha! Installed 3DMark99 again on my Ryzen build (Windows has been reinstalled since my last attempt), and now I have the same "0 FPS" issue on the Ryzen as well (with or without dgVoodoo). This is indeed strange!
Unfortunately, without the 3DMark source code it would be very hard to debug, as you need to dive deep into assembly language...
Reply 252 of 415, by Aebtdom
My "new" Diamond Viper V770 Ultra on my XP2400+ CPU.
Diamond driver 368.
The attachment 20210720_144440.jpg is no longer available
The attachment 20210720_144452.jpg is no longer available
Not the least disapointed with these results.
Builds:
Reply 253 of 415, by AlexZ
My PIII 600 scores 4800 in 3D Mark 99 in 640x480-1024x768 regardless of bit depth with Geforce FX5600. With Voodoo2 it is 3100 3D Marks in 640x480x16bit. I didn't switch off vsync though.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 254 of 415, by Aebtdom
AlexZ wrote on 2021-07-21, 16:12:
But... you are using a p3 600mhz with a fx5600.
It doesnt matter to the graphics card which res you use... this is all the frames the cpu can offer the graphics card to render.
Builds:
Reply 255 of 415, by bloodem
Aebtdom wrote on 2021-07-22, 12:11:
He would get a higher score with a GeForce 2 / GeForce 3 with period correct drivers. 😀
From my benchmarks: a Pentium 3 Katmai 600 (OC @ 672 MHz / FSB 112) with a GeForce 3 Ti 200 I got 6388 points.
I think even a Riva TNT2 Pro would get a very high score.
Reply 256 of 415, by AlexZ
bloodem wrote on 2021-07-22, 14:17:
I'm using the latest drivers for Windows 98 which is not the best choice. Once I have more time I will test multiple driver versions.
Reply 257 of 415, by bloodem
AlexZ wrote on 2021-07-22, 16:05:
Even the oldest drivers that work with the FX5600 are too new. Although this is less of a problem with Pentium 3 compared to Socket 7.
Anyway, it depends on what you play. Benchmarks are only part of the story. As long as the games you're playing run OK, you've got nothing to worry about. 😀
Reply 258 of 415, by AlexZ
bloodem wrote on 2021-07-22, 17:09:
Unfortunately there is no Geforce 3 on sale here. FX5200-5600 are extremely cheap, that's why I got it. With PIII 733Mhz CPU, 133FSB score went up to 5700. But unfortunately system is not 100% stable with 133Mhz FSB.
Reply 259 of 415, by Aebtdom
Rerun of my Diamond Viper V770 Ultra.
The attachment 20210809_164523.jpg is no longer available
The attachment 20210809_164536.jpg is no longer available
Builds:
