Reply 820 of 1126, by Chadti99
- Oldbie
Limpem wrote on 2021-06-28, 12:16:Thanks! :D Tomb Raider doesn't have a built-in benchmark, but you can display the current fps (I think with F3 but it might be F […]
Thanks! 😁
Tomb Raider doesn't have a built-in benchmark, but you can display the current fps (I think with F3 but it might be F4 or F2 on the keyboard).
There is a frame-limit of 30FPS, but especially in larger area's the framerate drops to 20'ish on my system at 1024x768.
It's possible to improve performance with single-buffering (I think F9) which makes it better, but I am very curious if the higher clocks would solve this as well 😁
On what CPU and clock speed?
