Reply 20 of 21, by stanwebber
Sphere478 wrote on 2023-01-03, 17:19:
will force installing a radeon 9800 xt driver accomplish the same effect?
the 9800 se/pro/xt 128/256bus all use the exact same driver.
Reply 21 of 21, by Sphere478
stanwebber wrote on 2023-01-05, 04:03:
You can force install different versions though. I understand that the underlying driver is the same but you can make it say other cards in display properties by forcing a different card when installing (updating) drivers
Alternatively, you can change the hardware ID with Rabit.
Not sure if this overrides the hardware level id or not.
Sphere's PCB projects.
