First post, by Nopa
I couldn't find it on quick Google search anymore. Was wondering when VA/IPS monitors with respective resolutions first introduced to the world.
Anyone with a WayBackMachine LCD archive?
SGI 1600SW (1600x1024) in 1998
IBM T220 (3840×2400) in 2001
Are the oldest two I can think of. Bear in mind though, the SGI uses OpenLDI (which hardly anyone used), and the T220 required 2x single link DVI... so in both cases you need special graphics hardware to run them.
Also check out the original Apple Cinema Display (1600x1024) a year after the SGI 1600SW which iirc uses only a single DVI.
It’s worth noting that widescreen PC LCD Monitors were very rare before 2003 (Apple being the exception)
2560x1600 is well uncommon at best
Only one common PC screen (Dell 3011 series) and Apple Cinema 30 (2004)
like that along with a bunch of strange off brand dim portable units
From what I can tell LCDs of that came out in 2004 and withered on the vine.
before 2010 that resolution was usually a custom one for CRTS only and never really took off for full size LCDs (probably only a dozen models of screens that were a blip 2004-2012)
2048x1536 is the traditional 21” VGA CRT monitor top end with respect to bandwidth and it really didn’t end up in the full size standalone lcd world.
*The only LCDs of that resolution are almost all under 13” in size and used in embedded and portable environments.
An example of a larger embedded screen
https://m.made-in-china.com/amp/product/20-In … -748544215.html
Since it was never used in the desktop environment I can’t really use an earliest year for it.
As for 1680x1050, that was a commodity resolution that was driven by TV manufacturers into the LCD Monitor space to save costs on dies and tooling, it really launched into monitors ~2003 with Apple as previous TV panels were rather large for a PC.
1920x1200 again was introduced by Apple 2003
In the pc world Both 1680x1050 , 1920x1200 were in 2004 for consumers. and even 1440p was introduced in 2006 but was rare
In the pc space none of the resolutions were all that common and in consumers hands until 2008+
spiroyster wrote on 2024-05-10, 13:08:SGI 1600SW (1600x1024) in 1998 IBM T220 (3840×2400) in 2001 […]
IBM T220 (3840×2400) in 2001Are the oldest two I can think of. Bear in mind though, the SGI uses OpenLDI (which hardly anyone used), and the T220 required 2x single link DVI... so in both cases you need special graphics hardware to run them.
Thanks. I found out IBM T220/T221's the 1st ever 4K 16:10 releasing in June 01'. I've seen a few 1999's Apple Cinema Displays on eBay currently. It seems to use a Single-link DVI-D though.
rmay635703 wrote on 2024-05-10, 14:02:It’s worth noting that widescreen PC LCD Monitors were very rare before 2003 (Apple being the exception) […]
like that along with a bunch of strange off brand dim portable unitsFrom what I can tell LCDs of that came out in 2004 and withered on the vine.
before 2010 that resolution was usually a custom one for CRTS only and never really took off for full size LCDs (probably only a dozen models of screens that were a blip 2004-2012)2048x1536 is the traditional 21” VGA CRT monitor top end with respect to bandwidth and it really didn’t end up in the full size standalone lcd world.
An example of a larger embedded screenhttps://m.made-in-china.com/amp/product/20-In … -748544215.html
1920x1200 again was introduced by Apple 2003In the pc world Both 1680x1050 , 1920x1200 were in 2004 for consumers. and even 1440p was introduced in 2006 but was rare
There were actually about 520+ LCDs released between 1995-2001 with most of them featured either VGA or DVI Single-link. https://energy.ec.europa.eu/system/files/2018 … 1995-2001_0.pdf
Later on are these models:
-86"
Dell C8618QT (14.09.2018)
-75"
Dell C7520QT (11.12.2019)
-70"
Dell C7016H (24.06.2016)
Dell C7017T (14.09.2018)
-65"
Dell C6522QT (26.04.2021)
-55"
Dell C5517H (01.03.2017)
Dell C5518QT (14.09.2018)
Dell C5519Q (12.01.2019)
Dell C5522QT (26.04.2021)
Dell E5515H (15.01.2015)
-49"
Dell U4919DW (24.12.2018)
Dell U4924DW (16.05.2023)
-47"
Dell LD4730 (02.03.2017)
Dell LD4730G (02.03.2017)
-43"
Dell P4317Q (08.06.2016)
Dell U4320Q (06.02.2020)
Dell U4323QE (14.02.2023)
-40"
Dell U4021QW (22.02.2021)
Dell U4025QW (12.03.2024)
-38"
Dell U3818DW (31.08.2017)
Dell U3821DW (22.02.2021)
Dell U3824DW (12.07.2023)
-34"
Dell C3422WE (15.03.2021)
Dell P3418HW (28.03.2018)
Dell P3421W (12.11.2020)
Dell P3421W (22.08.2023)
Dell P3421WM (24.01.2022)
Dell P3424WE (23.08.2023)
Dell P3424WEB (19.12.2023)
Dell S3422DW (22.05.2021)
Dell S3422DWG (14.06.2021)
Dell S3423DWC (07.04.2022)
Dell U3415W (06.12.2013)
Dell U3417W (20.02.2017)
Dell U3419W (13.09.2018)
Dell U3421WE (14.12.2020)
Dell U3423WE (28.02.2023)
Dell U3425WE (12.03.2024)
-32"
Dell G3223D (22.03.2022)
Dell G3223Q (20.06.2022)
Dell P3221D (04.11.2020)
Dell P3222QE (30.06.2021)
Dell P3223D (22.03.2022)
Dell P3223DE (21.03.2022)
Dell P3223QE (25.07.2022)
Dell S3220DGF (23.10.2019)
Dell S3221QS (27.08.2020)
Dell S3221QSA (23.05.2023)
Dell S3222DGM (30.06.2021)
Dell SE3223Q (25.07.2022)
Dell U3219Q (13.09.2018)
Dell U3223QE (20.03.2022)
Dell U3223QZ (24.08.2022)
Dell U3224KBA (12.07.2023)
Dell UP3214Q (08.11.2013)
Dell UP3216Q (29.12.2015)
Dell UP3218K (04.07.2017)
Dell UP3221Q (12.11.2020)
-30"
Dell 3007WFP (24.12.2005)
Dell 3007WFP-HC (30.01.2007)
Dell 3008WFP (27.11.2007)
Dell U3011 (19.10.2010)
Dell U3014 (02.03.2013)
Dell U3023E (20.03.2022)
Dell UP3017 (20.02.2017)
-29"
Dell U2913WM (08.10.2012)
Dell U2917W (20.02.2017)
-28"
Dell P2815Q (06.12.2013)
Dell S2817Q (08.06.2016)
-27 "
Dell 2707WFP (30.01.2007)
Dell 2709W (03.07.2008)
Dell 2709WFP (20.12.2013)
Dell C2722DE (10.03.2021)
Dell C2723H (21.03.2022)
Dell D2721H (04.11.2020)
Dell E2715H (15.01.2015)
Dell E2720H (27.01.2020)
Dell E2720HS (27.01.2020)
Dell E2722H (09.11.2021)
Dell E2722HS (08.11.2021)
Dell E2723H (18.10.2022)
Dell E2723HN (21.03.2022)
Dell E2724HS (28.02.2023)
Dell G2722HS (21.03.2022)
Dell G2723H (18.10.2022)
Dell G2723HN (20.06.2022)
Dell G2724D (11.07.2023)
Dell P2714H (27.09.2013)
Dell P2714T (09.11.2013)
Dell P2715Q (15.01.2015)
Dell P2717H (08.06.2016)
Dell P2717H (10.06.2016)
Dell P2719H (24.08.2018)
Dell P2719HC (03.09.2018)
Dell P2719HC (14.01.2020)
Dell P2720D (09.12.2019)
Dell P2720DC (09.12.2019)
Dell P2721Q (04.11.2020)
Dell P2722H (29.06.2021)
Dell P2722HE (29.06.2021)
Dell P2723D (22.03.2022)
Dell P2723DE (21.03.2022)
Dell P2723QE (22.03.2022)
Dell P2724DEB (22.01.2024)
Dell S2715H (28.08.2014)
Dell S2716DG (05.12.2015)
Dell S2718D (26.04.2017)
Dell S2718H (26.04.2017)
Dell S2718HN (03.04.2017)
Dell S2718HX (26.04.2017)
Dell S2718NX (14.03.2017)
Dell S2719DC (13.09.2018)
Dell S2719DGF (22.12.2018)
Dell S2719DM (28.03.2018)
Dell S2719H (25.05.2018)
Dell S2719HM (28.03.2018)
Dell S2719HN (19.07.2018)
Dell S2719HS (16.12.2019)
Dell S2721D (27.08.2020)
Dell S2721DGF (19.08.2020)
Dell S2721DGFA (30.11.2020)
Dell S2721DS (27.08.2020)
Dell S2721H (27.08.2020)
Dell S2721HGF (23.09.2020)
Dell S2721HGFA (21.07.2023)
Dell S2721HN (27.08.2020)
Dell S2721HSX (24.09.2020)
Dell S2721QS (27.08.2020)
Dell S2721QSA (12.07.2023)
Dell S2722DC (27.08.2021)
Dell S2722DGM (30.06.2021)
Dell S2722DZ (08.11.2021)
Dell S2722QC (08.09.2021)
Dell S2723HC (20.06.2022)
Dell S2725DS (04.04.2024)
Dell S2740L (26.09.2012)
Dell SE2716H (14.10.2015)
Dell SE2717H (20.02.2017)
Dell SE2719H (24.12.2018)
Dell SE2719HR (24.10.2019)
Dell SE2719HX (24.12.2018)
Dell SE2722H (29.05.2021)
Dell SE2722HX (14.06.2021)
Dell SE2723DS (25.07.2022)
Dell U2711 (14.02.2010)
Dell U2713H (09.01.2013)
Dell U2713HM (21.08.2012)
Dell U2713HM (s) (07.07.2014)
Dell U2715H (09.12.2014)
Dell U2717D (08.06.2016)
Dell U2717DA (08.06.2016)
Dell U2717DWH (03.03.2017)
Dell U2718Q (26.04.2017)
Dell U2719D (22.12.2018)
Dell U2719DC (17.02.2020)
Dell U2719DX (22.12.2018)
Dell U2720Q (06.02.2020)
Dell U2721DE (18.05.2020)
Dell U2722D (22.04.2021)
Dell U2722D (25.09.2023)
Dell U2722DE (22.04.2021)
Dell U2723QE (20.03.2022)
Dell U2724D (19.12.2023)
Dell U2724DE (19.12.2023)
Dell UP2715K (15.01.2015)
Dell UP2716D (21.12.2015)
Dell UP2716DA (22.04.2021)
Dell UP2718Q (25.04.2017)
Dell UP2720Q (28.01.2020)
Dell UP2720QA (16.05.2023)
Dell UZ2715H (28.08.2014)
-25"
Dell G2524H (11.07.2023)
Dell S2522HG (29.05.2021)
Dell U2515H (15.01.2015)
Dell U2518D (26.04.2017)
Dell U2520D (06.02.2020)
Dell UP2516D (20.12.2015)
-24"
Dell 2405FPW (02.02.2005)
Dell 2407WFP (08.06.2006)
Dell 2407WFP-HC (30.08.2007)
Dell 2408WFP (15.02.2008)
Dell C2422HE (15.03.2021)
Dell C2423H (21.03.2022)
Dell D2421H (04.11.2020)
Dell E2414H (13.08.2013)
Dell E2416H (29.09.2015)
Dell E2417H (20.02.2017)
Dell E2418HN (07.01.2018)
Dell E2420H (28.01.2020)
Dell E2420HS (28.01.2020)
Dell E2421HN (04.11.2020)
Dell E2422H (17.11.2021)
Dell E2422HN (17.11.2021)
Dell E2422HS (17.11.2021)
Dell E2423H (18.10.2022)
Dell E2423HN (21.03.2022)
Dell E2424HS (28.02.2023)
Dell E248WFP (19.10.2007)
Dell G2410 (29.01.2009)
Dell G2410H (04.04.2010)
Dell G2422HS (21.03.2022)
Dell MR2416 (18.02.2017)
Dell P2411H (19.10.2010)
Dell P2412H (09.09.2011)
Dell P2414H (27.09.2013)
Dell P2414H (10.06.2016)
Dell P2415Q (15.01.2015)
Dell P2416D (12.06.2015)
Dell P2417H (08.06.2016)
Dell P2417H (20.02.2017)
Dell P2418D (06.01.2018)
Dell P2418HT (14.09.2018)
Dell P2418HZ (26.04.2017)
Dell P2418HZm (12.11.2020)
Dell P2419H (31.08.2018)
Dell P2419HC (03.09.2018)
Dell P2419HC (14.01.2020)
Dell P2421 (11.05.2020)
Dell P2421D (05.03.2020)
Dell P2421DC (05.03.2020)
Dell P2422H (29.06.2021)
Dell P2422HE (29.06.2021)
Dell P2423 (21.03.2022)
Dell P2423D (22.03.2022)
Dell P2423DE (21.03.2022)
Dell P2424HEB (22.01.2024)
Dell S2409W (28.08.2008)
Dell S2415H (28.08.2014)
Dell S2417DG (20.02.2017)
Dell S2418H (26.04.2017)
Dell S2418HN (03.04.2017)
Dell S2418HX (26.04.2017)
Dell S2418NX (14.03.2017)
Dell S2419H (25.05.2018)
Dell S2419HGF (22.12.2018)
Dell S2419HM (28.03.2018)
Dell S2419HN (19.07.2018)
Dell S2421H (27.08.2020)
Dell S2421HGF (03.07.2020)
Dell S2421HN (27.08.2020)
Dell S2421NX (24.09.2020)
Dell S2422HG (18.03.2021)
Dell S2422HZ (08.11.2021)
Dell S2425HS (04.04.2024)
Dell S2440L (26.09.2012)
Dell SE2416H (14.10.2015)
Dell SE2417HG (26.04.2017)
Dell SE2417HGX (19.09.2019)
Dell SE2419H (24.12.2018)
Dell SE2419HR (24.10.2019)
Dell SE2419HX (24.12.2018)
Dell SE2422H (29.05.2021)
Dell SE2422HX (14.06.2021)
Dell ST2410 (14.12.2009)
Dell ST2420L (17.09.2010)
Dell ST2421L (19.10.2010)
Dell U2410 (21.09.2009)
Dell U2412HM (29.08.2011)
Dell U2412M (04.08.2011)
Dell U2412M (s) (22.02.2012)
Dell U2412M (w) (18.02.2017)
Dell U2412MWh (31.08.2017)
Dell U2413 (28.01.2013)
Dell U2414H (06.01.2014)
Dell U2414H (210-ADTW) (21.02.2017)
Dell U2414H (b) (07.07.2014)
Dell U2415 (28.08.2014)
Dell U2417H (08.06.2016)
Dell U2417HA (08.06.2016)
Dell U2417HJ (21.02.2017)
Dell U2417HWH (27.04.2017)
Dell U2417HWi (10.06.2016)
Dell U2419H (22.12.2018)
Dell U2419H (17.02.2020)
Dell U2419H-WOS (24.12.2018)
Dell U2419HC (31.05.2019)
Dell U2419HX (22.12.2018)
Dell U2421E (08.10.2020)
Dell U2421HE (18.05.2020)
Dell U2422H (22.04.2021)
Dell U2422H (14.06.2021)
Dell U2422HE (22.04.2021)
Dell U2424H (19.12.2023)
Dell U2424HE (19.12.2023)
Dell U2424HWOS (19.12.2023)
Dell UP2414Q (02.12.2013)
-23"
Dell E2310H (22.09.2009)
Dell E2311H (19.01.2011)
Dell E2313H (10.12.2012)
Dell E2314H (03.12.2013)
Dell E2316H (29.09.2015)
Dell E2318H (06.01.2018)
Dell E2318HN (06.01.2018)
Dell P2310H (21.09.2009)
Dell P2311H (18.06.2010)
Dell P2312H (20.11.2011)
Dell P2314H (27.09.2013)
Dell P2314H (s) (07.07.2014)
Dell P2314T (16.10.2013)
Dell P2317H (10.06.2016)
Dell P2317HWh (20.02.2017)
Dell P2319H (31.08.2018)
Dell P2319HC (03.09.2018)
Dell S2309W (29.01.2009)
Dell S2316H (16.10.2015)
Dell S2318H (26.04.2017)
Dell S2318HN (07.06.2017)
Dell S2318HX (26.04.2017)
Dell S2318M (07.06.2017)
Dell S2318NX (14.03.2017)
Dell S2319H (25.05.2018)
Dell S2319HN (19.07.2018)
Dell S2319HS (16.12.2019)
Dell S2330MX (07.09.2011)
Dell S2340L (26.09.2012)
Dell S2340M (26.09.2012)
Dell S2340T (10.11.2012)
Dell SP2309W (28.01.2009)
Dell ST2310 (21.09.2009)
Dell ST2320L (17.09.2010)
Dell U2311H (18.06.2010)
Dell U2312HM (29.08.2011)
Dell U2312HM (s) (28.09.2011)
Dell UZ2315H (03.07.2014)
-22"
Dell 2208WFP (27.11.2007)
Dell 2208WFP (without stand) (19.11.2009)
Dell 2208WFP AIO SFF (12.05.2009)
Dell 2209WA (b) (28.01.2009)
Dell 2209WA (s) (28.01.2009)
Dell Crystal (03.07.2008)
Dell E2209W (b) (29.01.2009)
Dell E2209W (s) (29.01.2009)
Dell E2210 (b) (21.09.2009)
Dell E2210 (s) (22.09.2009)
Dell E2210-BLK (07.09.2011)
Dell E2210H (22.09.2009)
Dell E2211H (19.10.2010)
Dell E2213 (31.07.2012)
Dell E2213H (10.12.2012)
Dell E2214H (03.12.2013)
Dell E2216H (29.09.2015)
Dell E2216HV (07.06.2017)
Dell E2218HN (29.08.2017)
Dell E2220H (28.01.2020)
Dell E2221HN (04.11.2020)
Dell E2222H (17.11.2021)
Dell E2222HS (14.09.2021)
Dell E2223HN (21.03.2022)
Dell E2223HV (21.03.2022)
Dell E228WFP (25.01.2007)
Dell G2210 (29.01.2009)
Dell P2210 (b) (12.05.2009)
Dell P2210 (s) (12.05.2009)
Dell P2210H (21.09.2009)
Dell P2211H (18.06.2010)
Dell P2212H (20.11.2011)
Dell P2213 (31.07.2012)
Dell P2213 (20.02.2017)
Dell P2213 (s) (07.07.2014)
Dell P2214H (27.09.2013)
Dell P2214H (10.06.2016)
Dell P2217 (18.02.2017)
Dell P2217-WOST (31.08.2017)
Dell P2217H (10.06.2016)
Dell P2217H (20.02.2017)
Dell P2217Wh (20.02.2017)
Dell P2219H (31.08.2018)
Dell P2219H (17.02.2020)
Dell P2219HC (03.09.2018)
Dell P2222H (30.06.2021)
Dell P2223HC (22.03.2022)
Dell S2209W (29.01.2009)
Dell S2216H (16.10.2015)
Dell S2218H (26.04.2017)
Dell S2218M (07.06.2017)
Dell S2230MX (07.09.2011)
Dell S2240L (26.09.2012)
Dell S2240M (26.09.2012)
Dell S2240T (07.08.2013)
Dell SE2216H (14.10.2015)
Dell SE2219H (24.12.2018)
Dell SE2219HX (24.12.2018)
Dell SE2222H (31.08.2021)
Dell SP2208WFP (06.02.2008)
Dell ST2210 (21.09.2009)
Dell ST2220 (31.01.2011)
Dell ST2220L (17.09.2010)
Dell ST2220M (19.10.2010)
Dell ST2220T (31.01.2011)
Dell ST2220T Multi-Touch (06.07.2011)
Dell SX2210 (22.09.2009)
Dell SX2210T (19.11.2009)
Dell U2211H (18.06.2010)
Dell U2212HM (29.08.2011)
Dell UZ2215H (07.07.2014)
-20"
Dell 2000FP (01.03.2003)
Dell 2001FP (01.03.2004)
Dell 2005FPW (06.11.2004)
Dell 2007FP (b) (27.10.2006)
Dell 2007FP (s) (27.10.2006)
Dell 2007FP Rev. V02 (b) (17.11.2006)
Dell 2007FP Rev. V02 (s) (17.11.2006)
Dell 2007WFP (20.04.2006)
Dell 2009W (b) (19.11.2009)
Dell 2009W (s) (19.11.2009)
Dell 2009WFP (b) (28.01.2009)
Dell 2009WFP (s) (28.01.2009)
Dell E2009W (28.01.2009)
Dell E2009W (s) (12.05.2009)
Dell E2010H (22.09.2009)
Dell E2011H (19.10.2010)
Dell E2013H (05.02.2013)
Dell E2014H (13.08.2013)
Dell E2014T (08.11.2013)
Dell E2016 (29.09.2015)
Dell E2016H (29.09.2015)
Dell E2016HV (18.02.2017)
Dell E2020H (28.01.2020)
Dell E207WFP (b) (14.10.2006)
Dell E207WFP (s) (27.11.2007)
Dell IN2010N (12.05.2009)
Dell IN2020 (19.10.2010)
Dell IN2030 (26.06.2012)
Dell IN2030M (26.08.2011)
Dell P2010H (21.09.2009)
Dell P2011H (06.09.2010)
Dell P2012H (20.11.2011)
Dell P2014H (06.11.2013)
Dell P2016 (21.12.2015)
Dell P2016H (16.10.2015)
Dell P2017H (10.06.2016)
Dell P2018H (31.05.2019)
Dell S2009W (04.05.2009)
Dell SP2008WFP (27.11.2007)
Dell SP2009 (28.08.2008)
Dell SP2009W (28.01.2009)
Dell ST2010 (12.05.2009)
Dell ST2010-BLK (14.07.2010)
-19"
Dell 1900FP (01.03.2003)
Dell 1901FP (01.03.2003)
Dell 1905FP (P-MVA) (13.02.2006)
Dell 1905FP (PVA) (11.11.2004)
Dell 1906FP AIO (17.10.2005)
Dell 1907FP (b) (13.02.2006)
Dell 1907FP (s) (13.02.2006)
Dell 1907FPV (b) (28.09.2006)
Dell 1907FPV (s) (28.09.2006)
Dell 1908FP (b) (23.04.2007)
Dell 1908FP (s) (23.04.2007)
Dell 1908FPT (b) (12.06.2015)
Dell 1908FPT (s) (12.06.2015)
Dell 1908WFP (27.11.2007)
Dell 1909W (b) (12.05.2009)
Dell 1909W (s) (12.05.2009)
Dell 1909W (without stand) (19.11.2009)
Dell 1909W SFF AIO (b) (04.05.2009)
Dell 1909W SFF AIO (s) (04.05.2009)
Dell 1909W USFF (19.11.2009)
Dell E1909W (b) (04.05.2009)
Dell E1909W (s) (04.05.2009)
Dell E190S (12.05.2009)
Dell E1910 (b) (22.09.2009)
Dell E1910 (s) (22.09.2009)
Dell E1910H (05.06.2009)
Dell E1911 (09.12.2010)
Dell E1912H (06.07.2011)
Dell E1913 (31.07.2012)
Dell E1913S (31.07.2012)
Dell E1914H (07.07.2014)
Dell E1916H (16.10.2015)
Dell E1920H (28.01.2020)
Dell E193FP (14.12.2004)
Dell E196FP (14.01.2006)
Dell E197FP (24.10.2006)
Dell E198FP (29.06.2007)
Dell E198WFP (29.06.2007)
Dell IN1910N (19.11.2009)
Dell IN1920 (19.10.2010)
Dell IN1930 (06.07.2011)
Dell P190S (b) (21.09.2009)
Dell P190S (s) (21.09.2009)
Dell P1911 (09.12.2010)
Dell P1913 (31.07.2012)
Dell P1913 (10.06.2016)
Dell P1913S (31.07.2012)
Dell P1914S (08.11.2013)
Dell P1914S (b) (07.07.2014)
Dell P1914S (s) (07.07.2014)
Dell P1917S (20.02.2017)
Dell P1917SWH (20.02.2017)
Dell S1909WN (04.05.2009)
Dell SE197FP (30.01.2007)
Dell SE198WFP (22.06.2007)
Dell SP1908FP (23.04.2007)
-18"
Dell 1800FP (01.03.2003)
Dell 1801FP (01.03.2004)
-17"
Dell 1702FP (b) (01.03.2003)
Dell 1702FP (s) (02.04.2005)
Dell 1703FP (01.03.2003)
Dell 1703FP (2) (01.03.2003)
Dell 1704FP (20.11.2004)
Dell 1704FPT (17.06.2005)
Dell 1704FPTT (08.05.2015)
Dell 1704FPV (24.05.2005)
Dell 1706FP (16.06.2006)
Dell 1706FPV AIO (17.10.2005)
Dell 1707FP (b) (13.02.2006)
Dell 1707FP (s) (13.02.2006)
Dell 1707FP AIO USFF (23.04.2007)
Dell 1707FPV (b) (28.09.2006)
Dell 1707FPV (s) (28.09.2006)
Dell 1708FP (b) (23.04.2007)
Dell 1708FP (s) (23.04.2007)
Dell E1709W (04.05.2009)
Dell E170S (05.06.2009)
Dell E1713S (19.03.2013)
Dell E1715S (07.07.2014)
Dell E171FP (01.03.2003)
Dell E171FP (2) (01.03.2003)
Dell E171FPp (01.03.2003)
Dell E172FP (01.03.2004)
Dell E173FP (14.09.2004)
Dell E176FP (14.01.2006)
Dell E177FP (25.08.2006)
Dell E178FP (29.06.2007)
Dell E178WFP (27.11.2007)
Dell IN1720 (14.07.2010)
Dell P170S (b) (21.09.2009)
Dell P170S (s) (21.09.2009)
Dell S1709W (28.08.2008)
Dell SE177FP (30.01.2007)
Dell SE178WFP (27.11.2007)
-15"
Dell 1504FP (01.03.2003)
Dell 1504FP (2) (01.03.2003)
Dell 1504FP HAS (01.03.2003)
Dell 1505FP (b) (24.05.2005)
Dell 1505FP (s) (24.05.2005)
Dell E151FP (01.03.2003)
Dell E151FPb (01.03.2003)
Dell E151FPp (01.03.2003)
Dell E152FPp (01.03.2004)
Dell E153FP (18.10.2004)
Dell E156FP (14.01.2006)
Dell E157FP (23.04.2007)
Impressive list making a database of every screen that was.
Notice however that 99%+ of the screens are the big 4 generic resolutions in non-wide aspects?
Notice further several have to be CRT not LCD.
There are only a small handful of screens with interesting resolutions in the 90’s one Compaq 1920x1200 which very interesting and likely very obscure and expensive in its era and about a dozen that had very strange resolutions that were meant primarily as a part of a HD video conferencing device.
As for 1680x1050 despite being lower than 1920x1200 was an afterthought resolution due to reusing TV production equipment. It really did launch in the mainstream with Apple unless we want to include screens primarily intended as TVs .
Similarly 2560x1600 was obsolete before it launched due to manufacturers standardizing to 16:9 to save tooling costs before any low cost mass market high end LCDs got entrenched.
That is the primary problem today, the unique resolutions that were once mid tier either don’t exist, use obsolete tooling/techor go high end because everyone wants mass production ready screens that use commodity tools to make commodity resolutions at commodity prices.
rmay635703 wrote on 2024-05-11, 02:37:There are only a small handful of screens with interesting resolutions in the 90’s one Compaq 1920x1200 which very interesting and likely very obscure and expensive in its era and about a dozen that had very strange resolutions that were meant primarily as a part of a HD video conferencing device.
Do you still remember the name of that 1990's 1920x1200 HP Compaq LCD?
I want to obtain one 90' 1200p and one 90' 1440/1600p LCDs for PQ experiment.
