Reply 20 of 76, by RacoonRider
- Oldbie
wrote:Did it come with thermal tape or similar?
It came with nothing, not even a box 😀 However, this must not be a problem, most people on this forum have thermal grease and epoxy in stock. I suggest putting small drops of epoxy on the clean corners of the chips after applying thermal grease on the chip itself. Perhaps I should also work with a grindstone a bit so that the cooler would cover the left TMU better (GENDAC chip is currently too high to be covered).
wrote:wrote:wrote:I think another question to ask as well is what system should one use for the "ideal" Voodoo 2 SLI configuration?
A regular Voodoo scales with a Pentium from 100 to 200 MHz. So a Voodoo 2 definitely needs something faster. A Pentium III is a good platform, for SLI a high clock speed, like 700 - 1000 MHz should do the trick.
A Pentium II isn't strong enough for a Voodoo 2 SLI setup?
Pentium II-450 is just about as far as it is rational to go with V2 SLI and not V3, if not for compatibility reasons. However, it is known that V2 scales well with CPUs up to at least 700 MHz.
Concerning Voodoo Graphics, I thought the card scaled with CPUs up to PII-333 or something around it.
http://www.tomshardware.com/reviews/3d-accele … step,51-17.html
