PCI Graphics Roundup - DOS
Reply 40 of 46, by Jackhead
The Serpent Rider wrote on 2020-07-30, 19:02:
Ah, SIS boards. Then it's correct probably, they're slower than Intel.
Ok i will upgrade to a FIC PT-2007 with Pentium 233Mhz and 64MB SD-RAM soon. Will see how this boost the Ark2000PV
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 41 of 46, by schlang
pentiumspeed wrote on 2020-07-30, 21:38:
What is the reason for Quake running on PIII 933 to produce less FPS even at 640x480?
What is best way to get Quake to have better frame rate, not the hard ware listed here for "PCI graphics round up - dos"?
Cheers,
quake just being quake, cpu based 3d rendering hit a wall. there was a reason why GLquake was developed afterwards
clueless1 wrote on 2017-11-21, 11:20:
When you get to GF4 and GF5, DOS performance starts to go down.
do you have some benchmarks for this? I thought all nvidia cards until geforce fx (5xxx) starting with riva128 shared the same 2d core.
I remember I DOS-benchmarked my K6-3 with a matrox mystique, riva 128, tnt2 ultra and gf3-500 against a gf4 4600, and the gf4 was the fastest in that setup
great comparison btw., always appreciated
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 42 of 46, by clueless1
schlang wrote on 2022-03-10, 11:53:
do you have some benchmarks for this? I thought all nvidia cards until geforce fx (5xxx) starting with riva128 shared the same 2 […]
I'll have to dig them up, I posted this about 5 years ago. 😀 They should be in a spreadsheet somewhere. I'll see if I can find anything and reply back.
Reply 43 of 46, by Pierre32
clueless1 wrote on 2022-03-10, 12:28:
When I benchmarked my PCI cards, my FX5200 didn't fare well.
32.33 KiB
Reply 44 of 46, by schlang
Pierre32 wrote on 2022-03-10, 12:59:
the 5200 was a disaster anyway, when coming from a gf4 it was a downgrade
Reply 45 of 46, by clueless1
So the GF4 I benched was an MX4000. That was the only GF4 I had during these tests, so I have no idea how a regular one would fare.
download/file.php?mode=view&id=132406
Reply 46 of 46, by schlang
appreciated, thank you
