First post, by Almoststew1990
- Oldbie
I was fortunate enough to pick up a whole bunch of PC parts for £5 the other day and it happened to include a Voodoo 3 2000 PCI. I have a couple of questions as this is my first Voodoo card.
- Can I run this at the same time as an AGP graphics card and easily switch which graphics card to use to render an image?
- I know some games from, idk, 1999 onwards had launchers that allowed you to select which display adapter to use. Would I need to plug the VGA cable into the voodoo or would the video signal "pass through" the AGP card, even if the AGP card isn't doing any of the rendering?
- Games that don't allow you to select the display adaptor would just default to the primary adaptor, likely whatever I have in the AGP slot (probably a MX 440). Or are glide games clever enough to 'detect' a voodoo card?
This would be on a Windows 98SE Slot A PC with an AMD 751 chipset.
