Pentium 1 - 60 MHZ - Graphics Card
First post, by Smack2k
Building a Pentium 1 - 60 MHZ machine with DOS 6.22 installed (maybe Win 3.11 but mostly for DOS). Trying to figure out what PCI Graphics Card to use:
Matrox Millenium 4 MB
TSENG ET4000
ATI Mach64
S3 Trio (various Trio versions)
S3 Virge
S3 Virge DX 4 MB
Looking for Opinions....
Reply 1 of 159, by matze79
Tseng ET6000 😁
I would opt for a Virge 325 with 4Mb, and a 3Dfx Voodoo 1 😀
So you can play S3D Games and 3DFx.
if you want excellent Video Quality and SuperB 2D Support in DOS i would go for ET6000 😀
Co2 - for a endless Summer
Reply 2 of 159, by Smack2k
I could go the Virge 325 4MB route....only issue is my second Voodoo1 card is a Canopus Pure 3D that I have tried to build a pass through cable for, but the signal isnt perfect after its built, colors are kind of washed out and the BIOS / POST Screens show in another color than white....I could try to re-wire it again and see how it goes....
But I can toss the Virge in for now and get it built...
Reply 4 of 159, by Smack2k
Would you still agree with going the S3 route though? I dont have an ET6000 so that is out, so S3 or Matrox Millenium would be my choices for now.....the system will be running DOS games primarily......
Reply 5 of 159, by clueless1
The Virge DX is faster than the Virge 325 and retains the compatibility. That would be my choice.
Reply 6 of 159, by leileilol
The Serpent Rider wrote:
Socket 4 Pentium is too weak for 3dfx.
If a 486 can use a 3dfx card usefully to much benefit (no CPU chokage on fpu-heavy software renderers), I can't see why not for an actually matured PCI platform. There's nothing more appropriate for the low-end than the 3dfx VG/V2 contrary to what the 3dfx powerholio fancult thinks about CPU bottlenecks insulting some kind of 3dfx legacy.
Reply 7 of 159, by The Serpent Rider
Which could be even faster in such scenario, due to much higher clocks. But it's still slow to my taste.
Reply 8 of 159, by matze79
its not fully combatible without tsr and other stuff..
Also 3Dfx works fine in Pentium 60, don't mind 😀 there still plenty of games you can play.
Many DOS Games with 3Dfx Support will benefit from it.
Archimedian Dynasty/Schleichfahrt, Carmageddon, Tomb Raider...
And early Glide Games also run perfect.
A Pentium 233MMX is already bottlenecked by V1.
i consider a 166Mhz CPU optimum for V1, unless you want to do crude things like running Q3A..
Reply 9 of 159, by The Serpent Rider
Archimedian Dynasty is extremely CPU limited at the later stages.
Reply 10 of 159, by FFXIhealer
If I have a 200MHz non-MMX Pentium in a Socket 7 MB with 64MB of EDO RAM (60ns) and running Windows 95 OSR 2 with an ATI Rage IIc 2MB PCI graphics card, would you recommend the Voodoo1 or the Voodoo2 for that system?
Reply 11 of 159, by clueless1
The TSR is S3VBE, which uses less memory than Univbe or SDD, and only needed for some SVGA games, which you probably won't be playing on a P60 anyway. What "other stuff" are you referring to?
I was answering OPs question on choosing between the options he stated. I think the Virge DX is clearly the best option of the six chipsets he listed.
I do like the idea of a Voodoo1 as an addition, though. But that wasn't his question. 😉
Reply 12 of 159, by gdjacobs
Do you want to focus on DOS games or Windows? The Voodoo 1 is fully compatible with every DOS Glide title (including the weird, statically linked ones), whereas the Voodoo 2 is better able to take you to the limits of Pentium CPUs.
Reply 13 of 159, by FFXIhealer
I don't have many DOS games, but I did download Tomb Raider and I can't get it to work on my Voodoo2 cards at all. This issue was described in a previous thread over a year ago and still has not been resolved. Mainly I stick within Windows for games, but I think with THAT system, I was going to have a blend of both. Although Duke Nukem 3D doesn't run particularly well on that system unless you put it in a lower resolution.
Does it help that I already have a Pentium 3 system with dual Voodoo2 cards in SLI running Windows 98 SE? 🤣 I just see the Voodoo cards are always stupid-expensive for the age of the cards. Voodoo1 cards usually carry a nearly $40 USD cost. Voodoo2 cards are similar, usually people wanting around $60 for a card. Since I'm in America, prices are higher and the cards are harder to find. It would be easier if I lived in Asia or something.
Reply 14 of 159, by dionb
Smack2k wrote:
Building a Pentium 1 - 60 MHZ machine with DOS 6.22 installed (maybe Win 3.11 but mostly for DOS). Trying to figure out what PC […]
TSENG ET4000
ATI Mach64
S3 Virge
S3 Virge DX 4 MB
Look at the dates of the components and see what matches:
Intel Pentium 60: 1993
Matrox Millennium: 1995
Tseng ET4000 (assumedly the ET4000W/32p): 1994
ATi Mach64: 1994/1995/1996 depending on version. The Mach64CX and GX are the ones that date to 1994
S3 Trio: anywhere from 1994 (Trio32, Trio64 without extra letters/symbols) to 1997.
S3 Virge: 1996
S3 Virge/DX: 1996
In other words, the ET4000 is the best definitive match, with the ATi Mach64 and S3 Trio possibly also.
Of course you don't have to stay period correct, but in that case you just choose whatever you want. The Millennium probably would give you the best analog image quality, the Virges the best VESA compatibility.
Reply 15 of 159, by feipoa
I was starting to think that I was the only one with this opinion.
I've slowly been compiling a list of 3dfx games which are playable on a Cx5x86-133 with a Voodoo2. Off the top of my head, GLQuake, GLDoom I, GLDoom II, Forsaken, Carmageddon, Descent I, Descent II, Tomb Raider, Tomb Raider Unfinished Business, Tomb Raider 2, Tomb Raider 3, MDK, Outlaws (using D3D better though) and Dark Forces 1 all are perfectly enjoyable in my opinion. With a Matrox G200 and D3D, TR2/3 also play fine, as does Outlaws, and Battlezone (marginal). More testing needed. Incoming (10 fps), Half-life, and Quake II are too slow though. For non-accelerated titles tested, Magic Carpet II and Duke3D (I think at 640x480) all play fine by my standards. Blood was too slow though. My threshold is pretty low, however I don't like to go much below an 18 fps average.
Reply 16 of 159, by The Serpent Rider
I don't find regular dips below 10 fps enjoyable or playable whatsoever.
Reply 17 of 159, by feipoa
The frame rates shown in that video wouldn't bother me, though my system does seem quite a bit faster. The lowest dip I saw on my system running that same demo was 14 fps, and I only saw it twice. Max 40+ fps. What bothers me far more than framerate is the lack of mouse support in the 3dfx patch for Descent 1. Not sure how that guy's system takes GLQuake, but my cx5x86-133 system w/voodoo2 scores 29.3 fps w/out sound and w/out any optimisation.
Reply 18 of 159, by mwdmeyer
Back in the day my Pentium 133 had a TNT2 M64 PCI! That opened a whole new world of games for me. So a Voodoo 1/2 in a Pentium 60 seems completely acceptable to me.
Reply 19 of 159, by appiah4
Of those cards only the ET4000 is a contemporary to the P5 core, so that gets my vote. S3 Trio and Mach64 got released one year after the P5 IIRC, Virge, Millennium are also several years off.
