First post, by danijelm
I'm not sure if she's in good threed, but I'll ask you here. I changed my TV, and I no longer have a component input with 5 round connectors. I have only a SCART input on which is written: "SCART / S-VHS / COMPONENT" my Xbox is connected with the SCART-RGB cable and works OK, the N64 works with the Composite cable, but I do not know how to connect the Wii. For that I have a component cable with 5 connectors. picture with composite is not so good
Is there any pinout how to make a scart connector? google is very confusing about that.
I speak sarcasm as a 2nd language
Reply 1 of 6, by Tiido
http://members.optusnet.com.au/eviltim/gamesc … t/gamescart.htm
This has all the needed info
Reply 2 of 6, by 133MHz
Component over SCART uses the Red / Green / Blue pins as Pr / Y / Pb.
S-Video over SCART uses Red as chrominance and Composte Video as luminance (though I once came across a satellite decoder box that put luminance on the Green instead).
You've got quite a versatile input for pretty much any oldschool system with the added convenience of being able to use SCART switchboxes. I recommend hooking up the N64 through S-Video if you haven't RGB modded it (NTSC models take any S-Video cable, PAL models require a few passive components on the Y/C lines).
http://133FSB.wordpress.com
Reply 3 of 6, by danijelm
Ok. If I understand correct I can make adapter like on this link + connect audio to pin 2 & 6?
http://www.stratos.pl/strony/12418.htm
For N64 i ordered s video cable.
Thanks for quick ansfer
Reply 4 of 6, by 133MHz
That is indeed correct. Similar adapters also exist for S-Video.
Keep in mind that if you have a PAL N64 you'll have to add some components to your S-Video cable to get a proper signal. For NTSC N64 this is not needed.
Reply 6 of 6, by danijelm
I made adapter for WII and its working. Need to choose component on TV and image is better than one composite input.
Thanks a lot.
