First post, by root42
- Oldbie
Besides running my 286 / VGA rig with an LCD screen with VGA input, I also want to grab the screen output using a pretty no name USB 3.0 capture device, that has HDMI input. It works fine with a cheapo HDMI to VGA converter that I picked up for a few bucks on Amazon.
However the cheapo converter cuts off some scanlines in the lower res modes, such as the 720x400 text mode and mode 13 games.
I am thinking on buying the OSSC 1.6 instead to get a proper solution. However I am wondering: is it the right solution? Does the OSSC support all or most VGA modes properly? Are things like overscan or picture position configurable?
What would other options be?
