First post, by Tiido
- l33t
I have always liked the Omega Drivers due to all the performance tweaks and extra features but unfortunately there were any only up to Radeon 9xxx cards. So one day I thought maybe I should try to incorporate the stuff from the final Omega Drivers into Catalyst 6.2 and TiidOmega was born 🤣.
I went through the INF files in the Omega drivers and copied various extra things over into the Catalyst 6.2 INFs. I have no clue if any of the enhancements work at all and if there's any performance difference, nor do I know what they actually do. I don't really play games anymore so there haven't been any sort of real testing as far as 3D stuff goes.
Main thing for me are support for various resolutions such as 1680x1050 and 1400x1050 (they will show up as 1048 rather than 1050 due to some bug in the driver) that stock drivers do not support without manually adding them via PowerStrip. I added several other resolutions too but I don't know if they alll work as I cannot test the highest resolutions.
I have also added ATI Xpress200 chipset GPU IDs to these drivers and have successfully used them on HP NX6125 laptop.
To install you have to manually supply the INF file during hardware installation. CPanel needs to be installed separately after the fact. You will probably need DirectX9.0c installed before everything also. Stuff like KernelEx seems not to get in the way.
http://www.tmeeco.eu/9X4EVER/GOODIES/TiidOmega/TiidOmega.rar (13.9MB)
