First post, by viper32cm
I just acquired a WinME-era PIII system from HP with a Geforce 2MX400 installed. The motherboard has a universal agp slot, without any keying for voltage. The system will boot with the GF2MX as well as my GF256 DDR. However, it will not even display the video BIOS with my GF4 TI4200 8X AGP card. This seems odd since I used that particular GF4 in another PIII system of similar vintage for years and even used it with my prior PII system with a 440BX. I've run into similar problems trying to run newer PCI cards in older Socket 5 and 7 boards, but I never would have expected to run into this problem with a universal AGP slot.
With the GF4 installed, the motherboard is beeping 1 long and 3 shorts as well as 1 long and 2 shorts.
Does anyone have any ideas as to what might be the problem?
Reply 1 of 3, by The Serpent Rider
That particular board does not like that particular card. Happens. And since it's HP, the board manufacturer is probably ASUS. My ASUS P3B-F is quite picky with video cards too.
Reply 2 of 3, by viper32cm
The Serpent Rider wrote on 2020-01-11, 19:33:
Yes, it's definitely an ASUS board, a CUV-NT. I suppose I could find a newer card built by ASUS.
Reply 3 of 3, by cyclone3d
viper32cm wrote on 2020-01-11, 19:46:
I doubt that will make a difference.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
