Reply 20 of 22, by peg
Because it basically does everything you could want, with excellent DOS compatibility, great image quality, and good 3d with glide support. They are also fairly common, although the PCI versions are a bit harder to find . The only real issue beyond the price is that they run pretty hot, so you need to be careful and make sure they are getting cooled properly. I still prefer the Voodoo 5, but that is getting expensive and hard to find, especially the PCI version.
