Reply 40 of 56, by mario990
- Newbie
I will replace FBI 500-0009-01 systems with Voodoo Diamond 3D II and ICUVGA-GW803 cards for the test.
Diamond 3D II has already soldered the new FBI 500-0009-01 I wrote about it in my first post, but I will exchange it and see what will happen ...
There is one more thing that puzzles me, TMU0 and TMU1 500-0010-01 systems were still dead when they were mounted on Diamond 3D II,
which may indicate a lack of power supply or connection with the FBI, you can see it here.
I did the test if the FBI Diamond 3DII correctly recognizes RAM with a full 4MB bank and 2MB desoldering, as you can see it recognizes correctly.
The log below ICUVGA-GW803 is good, despite the fact that TMU0 and TMU1 500-0010-01 had one leg broken off.
This leg connected with the memory, so the log is correct and the game Need For Speed III crashed due to a problem with texturing.
