First post, by ElBrunzy
- Oldbie
Hi, I have a cl-gd5446 pretty much like this one. You will notice the 26 pins male connector on the upper left of the picture, correct me if I'm wrong but I've always called that a vesa connector. I never was really sure what it is, but I guess it's an output of the video signal since some capture and mpeg acceleration card connect there to get the normal video signal. So I assume it's an output pretty much like the standard vga blue connector we all know.
My goal is to hook a component/composite output from it, so I could see that computer from a monitor that only support that signal on PiP when the KVM switch focus on another computer. I have difficulty finding out the pinout of that connector maybe because I'm not searching for the good name ?
Any help with my project would be much appreciated.
