First post, by tyami94
Hi everyone,
I've just acquired an AOpen AX4SG-UN (Socket 478) board, and I'm having a very odd issue. My hardware is probably a bit newer than what you guys normally deal with, but I figured you all would be able to offer the most relevant advice.
I cannot get my 9700 Pro to work on this board, and I cannot figure out why. For all intents and purposes, it should be compatible. The system POSTs and boots fine without the card installed, but when I install it the system will not power up at all (no fans or anything). The AGP protection LED comes on whenever the card is installed, which the manual says is supposed to prevent 3.3V cards from burning out the chipset (It only supports 1.5v and .8V cards). Based on what I've gathered, the 9700 Pro is a universal 3.3V/1.5V card, so I have no idea why protection is kicking in.
Can any of you guys help me out a little bit? I don't know if I'm missing something obvious, or if there is something that I forgot to configure, etc. I've attached the manual for the board, but it doesn't look like I'm missing anything.
Thanks in advance,
--Tyler
