First post, by TeddyNoir
Hi everyone!
I've been trying to figure out how to make a modern 144Hz display work with my Windows XP machines. Recently, I've had two CRTs fail, so I decided to look for an LCD replacement that retains at least some of the desirable properties of a CRT. I went for an Asus VG279Q (27-inch, 144Hz, 1080p, 82dpi). A nice monitor, but I'm stuck with a number of issues.
I'm posting this here because I'm sure there are other, more technically knowledgable people that have encountered similar issues and made better progress than I have.
Generally, we're dealing with issues regarding detection of display capabilities, resolution timings, refresh rates and display scaling behavior.
I've got four Windows XP systems on hand, and I'll go through each one of them in detail. The VG279Q is connected to each of them via dual link DVI. The monitor itself provides scaling options for stretched 16:9 and 4:3 output, but sadly no option for 1:1 pixel mapping.
1. Core i5 3570K / Geforce GTX 670 / Win XP + Win 7 dual boot:
Under Win 7, everything works as it should: all available (including custom) resolutions can be used with all supported refresh rates (144, 120, 100, 85, 60 Hz). Moreover, with each display mode, centered timings (no scaling) work perfectly.
Under Win XP, however, the Geforce drivers treat the monitor as an HDTV. This locks away the usual display scaling options. Every non-native resolution is stretched to full size. Even worse, refresh rate options are severely limited: only 1080p can do all supported refresh rates. I've tried various driver releases, from 301.42 to 368.81, the result is always the same. I've also tried a suggestion I found online which involves adding a specific OverrideEdidFlags0 value to the registry (http://www.voetsjoeba.com/misc/edid/). This did not have the desired result and only messed up resolution options. I may have done something wrong, though, and should research into this further. 😒
Bottom line: I swapped the GTX 670 with a Radeon HD 7970 and everything works perfectly: arbitrary combinations of non-native resolutions and high refresh rates with centered output. (Catalyst version 14.4, using the gpu scaling option.)
One thing I've noticed: When a centered output of, say, 1280x960 @ 120Hz does work, the display OSD reports 1920x1080 @ 120Hz, i.e. native resolution. The display itself seems to offer 144-85Hz only @ 1920x1080. When creating a custom resolution, i.e. 1280x960, I've had varying results on diffrent configurations: you either get the monitor to display a fully stretched 1280x960 (reported by the osd as such), or a 1920x1080 with a centered 1280x960 of active pixels. You can probably tell that I'm getting out of my depth here.
2. Core 2 Duo E8600 / Radeon HD 4890 / Win XP only:
With the prior experience of the HD 7970, I expected this to be smooth sailing. Not even close. I've tried Catalyst ver. 11.9 and 13.4. GPU scaling behavior is apparently quite different here: centered timings work, but only at a 1920x1080 @ 60Hz. (As reported by the OSD, but also quite obvious perceptually.) Forcing e.g. 120Hz may fool Windows into reporting 120Hz, but it's always just 60Hz. That means that higher refresh rates are off the table for most non-native resolutions. I say 'most': When GPU scaling is disabled, my custom resolutions of 1440x1080 and 1728x1080 (4:3 and 16:10 respectively) are displayed as centered, i.e. mapped 1:1, with all higher refresh rates working. ... weird, but I'll take it. It would be nice to have resolutions with <1080 working @ >60Hz as well, though.
3. Athlon 64 X2 / Geforce 7900 GTX / Win XP only:
Initially, I had a 8800 GTX in this one. All the drivers I tried had the above mentioned HDTV (mis-)detection issue, so I swapped in a 7900 GTX and installed Forceware 93.71. Lo and behold: the 93.71 control panel still has the option 'Treat as HDTV', which I unticked. Why on earth did they get rid of that option in later versions? Anyway, while proper scaling options are now available, centered output only works with some resolutions and only at 60Hz (1920x1080 @ 60Hz as reported by the monitor OSD).
Now, the Forceware control panel allows for rather in-depth creation of custom resoltions. While I'm mostly out of my depth with the various timing options, I tried my luck using automatic settings, combined with the 'centered' setting and the the desired resolution values as front-end active pixels. This way, I got some resolutions working: the above mentioned 1440x1080 and 1728x1080, as well as 1280x1024, 1280x960 and 1152x864. Interestingly, all of these only work at 120Hz. Using 144Hz or 100Hz, the control panel reports a failure to set the respective resolution. I've tried manual settings based on the automatically determined values, always resulting in failure. One thing to note: with the working custom resolutions, back-end active pixels are always automatically determined as 1920x1080. If back-end active pixel values are below that, the output won't be centered, but fully stretched. Manually setting these values to 1920x1080 always failed, but this may be caused by other timing settings being incorrect.
4. Athlon 64 / Radeon X850XT AGP:
Using Catalyst 10.2. Neither centered output nor high refresh rates work, at all. Windows does not even pick up the higher refresh rates at native rasolution, only giving the option for 6Hz. The Catalyst control panel does pick up the refresh rates, but applying one of them, even at native resolution, results in a black screen. Scaling options are available in the control panel, but have no effect.
I've resorted to using my last working CRT with this system.
So, I've had some half-way success with all of this, but the current situation isn't exactly ideal. Even with the older video cards, I suspect that software - the display driver and the way it talks to the monitor -, rather than hardware is at the bottom of the issue. Maybe someone who knows the ins and outs of resolution timings, EDID and whatnot is willing to shed some light into to this mess.
Reply 1 of 8, by Jonsmith0815
Interesting thread!
I tried a GeForce 7900gs with a xg2401 1080p 144hz Monitor using a dvi to hdmi passive Adapter in Windows xp and 93 drivers, but I couldn’t get more than 60hz or 65hz to work.
It turns out that hdmi supports only dvi single link which is 60hz max in 1080p.
Now I think about buying a Monitor with dvi dual link and 144hz Support.
But I can‘t find any information about the maximum refresh rate that the 7900gs can support at 1080p.
Does anyone know the maximum refresh rate the 7000 series GeForce support in 1080p?
Reply 2 of 8, by jmarsh
Jonsmith0815 wrote on 2021-02-15, 05:36:
You probably won't find a decent 144Hz monitor with DVI input. Early high framerate monitors were pretty poor and by the time they improved DVI was replaced with DisplayPort. So assuming your card can actually output 144Hz you would need an active DVI to DisplayPort adapter to use it with a newly bought monitor.
Reply 3 of 8, by Boohyaka
jmarsh wrote on 2021-02-15, 06:54:
You are right that DP quickly became the norm but still there are a few options, for example I have an ASUS VG278, a 27" 1080p/144Hz/2ms TFT panel that I run with DVI that was a brilliant gaming monitor when I got it and that I still use as a secondary screen today. It also has HDMI and VGA which can come in handy, but obviously won't support 144Hz with those. I remember at the time I was looking at a similarly specced Acer as well.
About XP and high refresh rates, I never managed to go above 100Hz (with DP and another screen, a 35" 2560x1080 Acer Predator Z35). 120Hz and 144Hz are available but picture is effed up. Reading in another thread, I learnt about DP HBR standards, and it seems XP may be stuck to HBR1 so it doesn't have the bandwidth to go higher? In any case my XP rig is running the screen at 2560x1080 in 100Hz just fine, but can't go above it. I tried lower resolutions and going above 100Hz but even then I get the same picture problems. So it may very well be a Nvidia drivers limitation as well? Happy to learn more about it in any case. This is just my experience and I didn't go very far with my tests, 100Hz is good enough.
Reply 4 of 8, by Jonsmith0815
I am again working on this 😉
I have the BenQ 2411z 144hz 1080p monitor that supports 144hz only over a dual link DVI cable and not via HDMI.
I use it with an Asus 7900gs AGP under 98 and XP. I am having problems getting more than 60hz to work. In 98 the modded drivers don’t offer a setting for setting a specific refresh rate. In XP i also have problems, the driver offers a setting for a the refresh rate but the monitor gives an error message at higher refresh rates.
I will try a 6800gt next under 98, as I am mainly interested in using 98 with this setup, because of Aureal A3D.
Did anyone else get higher refresh rates to work over DVI in 98/XP?
Reply 5 of 8, by agent_x007
Based on : (desired horizontal res.) X (desired vertical. res.) X (desired refresh rate)/1.000.000 X 1.53 for RAMDAC speed.
For 144Hz to work at 1080p, you need 450MHz+ RAMDAC. GF6/GF7 has 400MHz RAMDAC, so it won't work on Single Link configuration (~120Hz is more realistic maximum limit in this case, assuming custom resolution program works at all).
You can use PowerStrip to add custom resolutions, however IT WILL make screen no show up after restart if you pushed things too far (at which point safe mode and PowerStrip removal are necessary to make things work again)
Reply 6 of 8, by Jonsmith0815
I tested Powerstrip custom resolutions, but it seems to be broken on this setup. At 1024x768 higher refresh rates up to 100Hz worked, but nothing worked at 1080p, only 60Hz. I read somewhere that the newer drivers are the problem. So I would need to use an older GPU and older drivers maybe. Which driver version supports 1080p and high refresh rates? Maybe something around 30? Probably GeForce 4200 or FX?
Reply 7 of 8, by Jonsmith0815
I tested 4200ti and 6800gt with all drivers from version 29 up to 66.94 with a dual link DVI cable at 1080p with my BenQ 2411Z.
Using both driver settings as well as power strip I was unable to achieve any refresh rates above 70Hz.
144Hz was working under XP with the 7900gs, didn’t test the other cards yet in XP.
So far, high refresh rates over DVI at 1080p seem to be impossible in windows 98.
I tried all possible ways of adding custom resolutions and refresh rates, nothing works. Powestrip just black screens all the time. Drivers 61 and 66.94 introduce an interface to add custom settings as well. But when I click add resolution I always get the error message can’t add resolution, and sometimes NVPCL error and sometimes something with system\Desk… which closes the display setting window.
Before that I also tried the 850XT AGP. That one didn’t allow 1080p wide screen resolutions. Not sure if I tried the power strip though.
I don’t have a high refresh rate CRT, only a Samsung 17glsi. May check that one sometime, to see if only the DVI is not working in 98.
I don’t know if there are any high refresh rate LCDs that use VGA cable. Probably some 4:3 viewsonics.
Anything high refresh rate related that I saw elsewhere seemed to involve the VGA output. So the question still is, are high refresh rates over DVI possible? And if so, what hardware is necessary?
Reply 8 of 8, by Jonsmith0815
Looking at the title of this thread, this might not be the right place to discuss Win98 high refresh rates.
As anything more than 1080p@60Hz requires DVI dual link, I guess that dual link support was never achieved under windows 98.
Looking back at the market in 2004, there seem to be not many displays available specifically for high refresh rates at the time. LCDs were still becoming a thing and fighting to improve the response time. So it makes sense that the DVI port support for higher refresh rates in windows 98 might have been lacking, as it wasn’t relevant anymore to justify possible required development time for it. So I will look more into VGA options for high refresh rates in Win98, until someone can confirm that they are possible in Win98 over DVI.
See also:
Re: DVI-D Dual-Link to HDMI 1.3+ Bidirectional Passive adapters/cables
Video card for Windows 98, with support for DVI Dual Link, for a modern DVI-D monitor (144Hz+).
Re: Trying some resolutions with old nVidia video cards on Win9x...
