First post, by son_dh
Hi everyone,
Though I have been using computer since 1998, but as a little kid back then I didn't know exactly how things work. Now I am in possess of an intel celeron 500 mhz, along with a s3 savage 4 graphic card (16MB memory).
I have installed Windows 98SE and the latest driver for the graphic card (DriverVer = 08/30/2000, 4.12.01.8226). The DirectX included in this Windows 98Se is Dx 9.0, I think.
Anywho, I tried installing Quake 1 and Quake 2, and both of the games run in software renderer mode. For Quake 1, I have tried GLQuake (didn't work), and I have tried default OpenGL option in Quake 2 and did not work either. I assume it's because this card does not support OpenGL at all, correct?
Is there anyway to make the game use the graphic card to render?
Reply 2 of 15, by Cyberdyne
Savage 4 is a slow, but feature ritch card. Opengl DirectX and af course S3TC. Good looking textures in newer games. And good compatible S3 VGA and VESA implementation. You just need good Windows drivers for functional 3D.
Reply 4 of 15, by The Serpent Rider
Drivers from vogons library already have OpenGL libraries. Alternatively you can download GLSetup.
Reply 5 of 15, by Con 2 botones
son_dh wrote on 2020-08-31, 16:27:
Cool, thanks for the answers guys. But I have downloaded the drivers, where (and how) do I get OpenGL for the card?
How did this turn out?
I currently have a Savage 4 Pro installed in a PII 450mhz, drivers are 8.20.31_win9X ( 4.12.01.8226).
You don´t need to install separate drivers for OpenGL, just install the main driver package.
What you do then, is copying "S3-MiniGL driver" inside the desired game, which consists in replacing a .dll named "opengl32.dll" with the one provided inside the S3-MiniGL driver package (not sure I can share links to ohter sites in this forum). This procedure only aplies to certain games (Quake 1&2 engine ones).
Both GlQuake and Quake2, not only work but look stunning, since this particular card outputs from DVI. The colours are impressively vivid.
I have tried a Voodoo 2 12MB with this system before and I don´t find any notorious performance difference in favor of the Voodoo 2 (this is a SGR vram based Savage 4 manufactured by "Number Nine"). When it comes to picture quality, it is more the other way around, the one coming from the S3 is terrific: sharp, crisp, vivid. Just average in the 3DFX one case.
Unreal looks excellent when ran through "S3 Metal" Api (see Phil´s Computer Lab episode on the Savage 4 to understand how to achieve it), and textures replaced by the improved ones (...).
I was also impressed this card ran Quake 3 and Unreal Tournament very well. You can even play Half Life at 640x480 with good framerate.
All that said, this is a card to play at 800x600 and 640x480 only , depending on the game, unless you don´t mind choppy framerate and stuttering. Its 64bit bus is to blame, I guess.
My only problems are in fact related with two 2D games, Age of Empires and Diablo, when you start them, you get just get image in the bottom left quarter of the screen. Weird, maybe I should try other driver. Any other ideas about it?
Reply 8 of 15, by Con 2 botones
I tried a DVI to D-Sub adapter and the image fills the whole screen as it should, when launching A.O.E and Diablo that way. Strange.
Reply 9 of 15, by pixel_workbench
Con 2 botones wrote on 2020-09-18, 13:26:
I have the same card Number 9 Savage4, and when connected with a DVI cable the maximum resolution I can get is 800x600. Had to use a VGA Dsub adapter to use higher resolutions.
Another issue I had with every Savage4 I tried is the menu screen corruption in Unreal Gold in D3D. You basically have to use the Metal API in that game.
But otherwise it's a good card, actually clocked like a Savage 4 Extreme. Substantially faster than the Diamond Savage4.
My Videos
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 11 of 15, by pixel_workbench
BigDaddyM wrote on 2020-09-19, 16:39:
What driver are you using? I have two No9 Savage4 extreme cards and no problems up to 1280x1024 resolution 😀
I tried several drivers like 8008, 8226, 8228 - all with the same result. I think the card just has buggy compatibility with LCD monitors.
Even when I try the card in XP, using the built in driver, if using DVI cable then any attempt to set a resolution above 800x600 fails with a black screen.
My Videos
Reply 14 of 15, by swaaye
Rank Moderator
Moderator
I think most DVI cards of that timeframe have a resolution limit of 1280x1024 / 1600x1024. If you connect it to a DVI monitor that uses a resolution beyond that you might have problems getting any output. It will probably have compatibility quirks with monitors nearing its resolution limit.
If it has nice VGA signal quality then there's nothing wrong with going that route.
Reply 15 of 15, by Con 2 botones
pixel_workbench wrote on 2020-09-19, 14:31:
I have the same card Number 9 Savage4, and when connected with a DVI cable the maximum resolution I can get is 800x600. Had to u […]
Well, it seems we´ve got some others (Number Nine) Savage 4 fans here. That´s good!
It seems this an OEM model that came inside IBM PIII systems (300GL).
In my case it is connected to one of those Dell UltraSharp line, with silver colour base, 5:4 aspetc ratio LCD. Can´t recall the exact model right now.
The problem seems to be occuring with 2D games (being Age of Empires Diablo and the only ones tested so far). As I stated above, when using a DVI-to-Dsub adapter the problem is gone.
I didn´t experience that up to 800x600 resolution limitation you mentioned above.
And yes, the corruption on Unreal´s menu screen does happen under DirectX too. I don´t mind to be honest beacause Metal is "the way it was meant to be played" for this card.
