Some things I learned doing this:
*Videos were often mastered for 8-bit color, but this is hard to do now. Virtualdub can palletize to 256 colors, but the dither is noisy, unattractive and not anything I've seen in vintage multimedia. There were some tools of the time, such as Debabelizer for Macintosh, that would index the colors in the video, make a custom optimal pallet, and dither the rest. Smacker does do this as it's a 256 color codec. Microsoft's free full version of Video for Windows with vidcap.exe and videdit.exe also can do this, but it's a 16-bit application and throws false lack of memory errors as far back as Windows 98 SE. My understanding is that by 1995 or so many video authors were mastering in high or even true color, and letting computers running at 256 colors dither on the fly.
*These early codecs introduce lots of artifacts even if allowed basically unlimited bandwidth and are very conservative in how much bandwidth they will use if given a high target data rate.
*Cinepak is a good all-around format for video, and was something of a gold standard for CD-ROM delivery targeting later 386s and 486s. It never seemed the best at anything, but it was always acceptable. Rather than tiling, it breaks up into a mosaic when starved. I like how it looks. It's a second generation codec, designed for a faster 386 or a basic 486.
Intel's Indeo was a real surprise. It performs unusually well for a second generation codec. Video was crisp, and it performed better at lower bit-rates than other computationally similar codecs. I think it didn't get used more because it wasn't very portable and PC and Mac encodes weren't cross-compatible. It also needed more processing power to decode, though still within the reach of a 486 or maybe even a fast 386.
Smacker was an unfortunate surprise. Its audio compression introduces terrible noise if set high. It also isn't very bit-efficient and is probably best used on a double-speed or faster drive when trying to play back full motion video. It also will need its own player on an older machine that won't be running -- and that player doesn't offer video scaling. FFMPEG can decode the format on a modern PC, but the codec seems kind of broken and won't always decode.
MPEG wasn't as universally best as I expected. It's a third-generation codec, and is generally much-improved over older codecs, but it has a propensity for heavy quilting which I find objectionable. XINGencoder, which was extremely common back in the day, leaves obvious quilting/mosaic even when given an unreasonably high bitrate. Which honestly, is how I remember MPEG 1 video looking in the 90s -- VHS-like, but with blockiness. TMPGenc exhibits a much better performance, but I can't get XING Player to read TMPGenc's output so I question its compatibility with legacy players. I think Indeo 4.1 performs better than Xing.
Microsoft Video 1 / CRAM is a multimedia potato. It is a first-generation codec, intended originally to deliver 160x120 10 FPS video on a 386sx/16. It needs a very high bit rate to work, and breaks up into a huge quiltwork when it's starved. It might also be useful on a slower 386 with a modern-ish IDE or SCSI CD-ROM drive, especially if you're not trying to do full motion video. I think CRAM was already becoming obsolete as multimedia became huge, by 1994 or so.
And Indeo 2.1 is NOT Indeo 3.2 by another name. It's an older, first-generation codec similar in sophistication to CRAM. I have no means of encoding to it, and Intel themselves never even put out a 32-bit decoder. I have seen amateur footage encoded from VHS, and the resulting videos were appalling.
