First post, by 386SX
Hello,
I'd like to ask if there are or there was a "modern" PCI (old bus) video card to be installed without needing a bracket and ver very low profile for mini-itx cases that doesn't have that option? Most low profile cards still need a big case anyway and I've built one with PicoPSU that doesn't have that. Also has the mini-pciex removed by factory.
Having a bridged PCI slot, can I install something to use some opengl/video accelerator? Even like a "Voodoo" add-on only card way? I understand this is a very specific and probably impossible solution.
Thanks.
