Video card upgrade for A64 X2 4400+
First post, by johnvosh
I am wanting to upgrade the video card in my Athlon 64 X2 4400+ system, but it is an AGP motherboard. I am running the MSI K8N Neo2 motherboard. While browsing eBay, I did find 3 or 4 cards that I was thinking might be decent upgrade. Of course they happen to be in Russia, but the sellers have very good feedback...
I was look at Sapphire Radeon X1950Pro 512MB 256bit AGP (CAD$135 w/ shipping), Powercolor Radeon HD 4650 1GB AGP (CAD$130 w/ shipping), has heatsink, but no fan, or a Sapphire Radeon HD 3650 512MB AGP (CAD$75 w/ shipping)
Reply 2 of 31, by johnvosh
pentiumspeed wrote on 2021-04-27, 00:41:
What you have not mentioned is target OS used. None of these will run on win 98SE.
Cheers,
It is going to be XP, as I have a few games that would do good from a better video card.
Going to be building a Win 98SE/ME system around a P3 1.4GHz eventually, when I can afford a motherboard.
Reply 3 of 31, by cyclone3d
What video card do you currently have?
What games are you wanting to play I'm XP?
Fastest AGP cards are:
ATI : 3850 / 4670
Nvidia : 7950GT
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 4 of 31, by winuser_pl
I would suggest to go with AMD cards like 3850 or 3650 instead GeForce 7 series. The main reason is because you get with more recent card, but also more energy efficient, better support for hardware video decoding. 3d performance etc.
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 5 of 31, by johnvosh
cyclone3d wrote on 2021-04-27, 01:31:
What video card do you currently have? […]
ATI : 3850 / 4670
Nvidia : 7950GT
I currently have a Radeon 9700 128MB video card in the system right now.
I've got RCT3, C&C 3, C&C Generals, SimCity 4, UT 3, UT 2004, GTA: San Andreas, NfS: Underground 1 & 2. Just a bunch of games that I want to have the details turned to the max
Reply 6 of 31, by johnvosh
winuser_pl wrote on 2021-04-27, 09:26:
Ya, I was looking more towards the ATI cards as that what I basically had during. I've only had one nVidia card, otherwise I've always gone ATI/AMD video cards.
Reply 8 of 31, by matze79
if you go HD3650 watch for (G)DDR3 VRAM, DDR2 Cards suck.
Co2 - for a endless Summer
Reply 9 of 31, by pixelatedscraps
How period correct do you want it or do you want best performance / bang for buck?
New: 5800x | 32GB | 3090 | EK custom | Mjolnir / MBP 16 2020
Old: FX-60 | 5970 | MP 5,1 | MBP 17’ | PB G4 Ti | G4 Cube | ACD HD 23'
INCOMING 97-98: Dual P-II 333Mhz | 384MB | Millenium II | Creative Blaster 3D Voodoo 2 | Sound Blaster AWE64 Gold
Reply 10 of 31, by pentiumspeed
Don't go with HD3650 video cards, I have not seen any that were GDDR3 or GDDR5. I had 3 as they were cheap and just right for the needs (daily use) at work and home but they work well but set the details on low. Was two PCIe and one AGP.
Go with 3850, 3870, 5850, 5870. I skipped 4870 was high failure, I received 4870 and it died minutes later few years ago.
Cheers,
Great Northern aka Canada.
Reply 11 of 31, by johnvosh
pixelatedscraps wrote on 2021-04-27, 13:14:
I was going to try and go somewhat period correct. It is running Windows XP, The motherboard was released July of 2004, the CPU was released May 2005. So could say that the motherboard and CPU were bought mid 2005. Of course my HDD is a 150GB Velociraptor and has a date of Jan 2010 on it. The monitor has a date of Dec 2006.
I was thinking something between mid-2005 to end of 2006 would probably be good for a video card...
Reply 12 of 31, by johnvosh
pentiumspeed wrote on 2021-04-27, 22:45:
Cheers,
In the listing I am watching, they show a picture of the back of the card and the sticker says HD3650 512M GDDR3 AGP TVO/VGA/DVI-I. It is AGP but requires a 6-pin PCI-E power connector.
Reply 13 of 31, by stef80
For the listed games X800/X850 native AGP should be ok. My go-to card is usually Connect3D X850Pro Vivo, because it's relatively cheap and there's good chance to unlock additional quad pipes.
X1650Pro/XT AGP with 256MB GDDR3 is also good choice. Runs FarCry (shader heavy game) much smoother then X800 series. I was surprised.
Only card that dissapointed me was HD2600XT with 512MB GDDR3. I did not expect it to suck so much being high-clocked DX10 piece of hardware. (HD3650 is about the same spec-wise. If with GDDR3! If not, then worse.)
X1950Pro is a killer, not sure if it's needed here.
I did not have any experience with AGP HD4670 or HD3850, so can't comment on that.
It may also be good idea to search for Asrock 939Dual-Sata2 / 939Dual-VSTA MBO for the given CPU. It offers both, native AGP and PCI-E 16x. Not easy to find, and they had problems with caps (fixable).
Reply 14 of 31, by candle_86
so the only issue game i really see is NFS:U2 its slow on cards from 2004, even the mighty x800 is slow with it, id look at an x1900GT AGP minimum
Reply 15 of 31, by johnvosh
candle_86 wrote on 2021-05-02, 00:55:
I ended up buying the Sapphire ATI Radeon HD 3650 512MB AGP GDDR3 card on ebay as it was the more reasonably priced card. Was CAD$70 shipped. Hopefully it will be here before the end of the month.
Reply 16 of 31, by johnvosh
Thank you everyone for the help! I decided to go with the 3650 GDDR3 512MB AGP card. I'm going to do some benchmarks with the 9700 Pro 128MB card, then again with the new card and I'll post my results!
Reply 17 of 31, by pentiumspeed
HD3650 GDDR3 will edge out the 9700 Pro some. 9700 Pro is around 19 GB/s memory bandwidth, and HD3650 GDDR3 around 25 GB/s, not much difference. Keep in mind this is directx 10.1 vs directx 9.0 especially if gaming in XP with games that is fussy. Also pixel per second is not that much also 9700 pro is 2.6 GP/s versus HD3650 2.9 GP/s.
Honestly, should had gotten x1800 or x1900 and easier to find in AGP favor and powerful 9.0c GPU, and HD3850 or HD3870 in PCIe is so inexpensive but they are directx 10.1
Checked the ebay and i find lack of AGP cards within your budget would push me to switch out the motherboard for PCIe with socket 939 motherboard and pick up, easy to get x1900 t0 keep with 9.0c support for XP. XP never had ventured beyond 9.0c. Well chosen socket 939 with PCle motherboard should not be that expensive.
When back in the day, I was not aware how hobbled the HD3650 were and the performance was only twice of what low end HD3000 series was, should had saved up some more and got PCIe HD3850 instead. Was because I was upgrading from Geforce2 MX and was still disappointed back in the day. Live and learn.
High end video card pushes out AA better vs low end would at any resolution.
Cheers,
Reply 18 of 31, by pixelatedscraps
johnvosh wrote on 2021-04-27, 23:26:
Man, then I'd go for an X1950XTX - pretty much the best single GPU card you could get in 2006. Also pretty cheap on eBay - I had my eye on one a couple of months ago for $40...
Reply 19 of 31, by vad4r
Maybe it's better to switch to a board with PCIe and a PCIe GPU, because the latest AGP cards are more expensive than the first PCIe cards with the same chips.
vae victis!
