First post, by BitWrangler
- l33t++
Hi folks,
Hope this isn't too un-retro, but the modern forums won't care about it, or "get" why messing with stuff that's not bleeding edge is still fun.
What I noticed is that the Fermi GPU in the GeForce GT 440 is the exact same one as in the GT 730 and dozens of others in between. Now officially, this might seem like an actual downgrade, since stock core clocks are meant to be 810 on the 440 and 700 on the 730, but that's not realllly an issue. Why the heck would I want to? Because various other software is stupid and might insist on needing a 710 minimum or something, when the 440 has the exact same feature set. Also the drivers are a few revisions more up to date, and there is a chance that the BIOS code got more efficient. Now I'm not out to sell fake 730s or anything, I was casting around to buy one, because I'm in want of an extra "one step off baseline" card, and you know the story, they're going for triple what they're worth. I do however have a 440 that needs a cooler, and I got to thinking I should fix that up.
I take it as a given that if I'm going to try it, the official nVidia flash tool will not let me, so I need another, and that I should match the spec of the 440 I've got and the 730 BIOS I use as closely as possible. I haven't looked yet whether you can still dink in your own core and RAM frequencies like back in the day. One sticking point might be the PCI device ID, is that blown into the GPU somewhere or will the BIOS have it in??
I also have a GT 610, which if this sort of thing works, I might like to bump up to something else, but options on that are a bit weird, like 705, non-standard 710, 800A(??) etc.
On the Radeon side, it seems like similar things should be possible between an HD6450 and an R5 230, both having Caicos Pro. I have a 6450 but not sure I'm going to bother with that, because the system using it is happy with it as it is.
I'm not getting much useful out of google, to be specific I have to enter several terms, and then it just barfs word salad with any 2 from 4 in at me. Lots of complaining about fake 730s from China that are 440s, but the big thing there seems to be that they are flashed to claim they have 4 GB of RAM while only having 1 or 2 installed, and thus they screw up.
So thoughts? Anyone done it? It's impossible because?
