Aebtdom wrote on 2021-07-08, 03:21:
It depends if you permanently want to overclock your voodoo cards, since that is one of the things this driver does. It caused some instability issues at my pc.
Inside the FastVoodoo 4.6 driver package there's also the Voodoo 2 overclocking tool, which basically adds a new display options tab. It will allow you to easily revert to the default 90 MHz clock (+ also disable vsync for both Direct3D and Glide).
I myself prefer to use the latest reference driver (I believe it's v3.02.02), I've never had any issues with it and find it to be very stable and compatible.
However, since the OP mentioned that he has a mixed Voodoo 2 SLI setup, that will only work with unofficial drivers like FastVoodoo.
By the way, just in case anyone is interested, the Voodoo 2 overclocking tool also works with the reference drivers.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
