First post, by matti157
I bought a Creative branded Voodoo2 12mb. I installed the drivers from the CD plus update for Windows 95
I have 2 problems: The games are very slow, unplayables. Even the 3dfx logo that starts before the game is very lagging
If I start 3dmark instead the benchmarks are seen with white textures. See this video https://youtu.be/ThRGD1eLbow
My pc is a Pentium MMX 233 with 64mb sdram
Any ideas? Is it fair that Windows only gives me 4mb of VRAM on voodoo? screenshots
Thanks
Reply 2 of 9, by Gmlb256
thepirategamerboy12 wrote on 2021-11-10, 03:41:
Perhaps try reference drivers instead of the vendor ones.
https://www.philscomputerlab.com/drivers-for-voodoo-2.html
I recall that the OP tried different drivers but on DOS where GTA was running unusually slow.
The card seems likely to be defective as I see only one TMU working according to the 3Dfx hardware profile, it should display 8MB for the texture memory if both TMU are working. Perhaps it should be checked with a Glide diagnostic tool called MOJO.EXE for better information.
Reply 3 of 9, by Aebtdom
What kind of CPU are cpu are you using?
And try a fastvoodoo driver, because your textures are really bad in 3dm99.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 4 of 9, by matti157
I tried the latest reference driver, but 3dmark99 refuses to start with these drivers
1.81 MiB
Attached the mojo output
My cpu is a pentium mmx 233
Any ideas?
    SST.log
    1.66 KiB
    37 downloads
    MOJO.TXT
    1.04 KiB
    46 downloads
    SSTV2.log
    1.75 KiB
    38 downloads
Reply 6 of 9, by Hoping
Gmlb256 wrote on 2021-11-10, 05:11:
Yes, something is not right, the voodoo2 has two TMUs, no multitexturing with one. Maybe missing components, or bent pins in the best scenario.
Reply 9 of 9, by LubieCipy
Can you upolad foto of the card? From the second screenshot you can see that only one TMU is functioning. First, let's see if the card looks good physically
