First post, by kolderman
I am testing this socket370 baord, and when I fire it up with the first GPU, the VGA quality is garbage. Like the monitor is not syncing right and all these lines moving upwards quickly on the screen.
I assume it's the card - so I try another one. Same issue. Try a PCI vga card. Same.
The issue is present from POST through to Win98.
What could be causing this? Could it be power conditioning or PCI freq issue on the mobo to affect multiple cards??
Reply 1 of 3, by BitWrangler
Bad regulation in my experience, usually needs a recap.
edit: can also be PSU putting out more crap than the motherboard can handle, check that too.
Reply 2 of 3, by kolderman
I'll try a different psu but it's generally ok with other mobos. Thanks.
Reply 3 of 3, by kolderman
Hey looks like it was the PSU after all!
