First post, by pc-sound-legacy
Hello friends, I recently got a Volari V3 and out of curiosity It'd played around with it. Does someone have such card and can provide the latest drivers for win9x and 2k? I found very rare information about this card and only one driver with poor performance. The way back machine has the xgi site but it's not compatible with modern browsers, thought.
I'm also interested in your experience with the card and it's performance.
Here are my results so far:
Q3 Timexemo 1 1024x786 high settings, 16bit textures and Z-Buffer, trilinear
Volari V3: 41 FPS
RV280 (Radeon 9250): 102 FPS
3DMark 2000 was scored something around 2700 as the RV280 managed to get around 5400.
Test system: Pentium IV 1.5 GHZ Willamette, 512mb SD-Ram and W2K.
Maybe the Volari demands a stronger CPU to perform better, but maybe it's just that slow:-)
The card has decent picture quality at least, supporting pixel and vertex shaders, bump mapping and texture compression. T&L unit is also slow in comparison with the ATI, High polygon count scenery has much lower FPS as well.
