First post, by GodModule
A small black rectangle inductor marked with 150k fell of the back of my Voodoo 3 3500, is it screwed?
-edit-
In one system (440bx), it wont post. There's 1 long beep 2 short beeps and no display . In another system (i815) it seems to post and run just fine.
Reply 1 of 8, by Doornkaat
GodModule wrote on 2022-10-11, 18:57:
A small black rectangle (SMD?) resistor marked with 150k fell of the back of my Voodoo 3 3500, is it screwed?
-edit-
In one system, it wont post. There's 1 long beep 2 short beeps and no display . In another system it seems to post and run just fine.
Which resistor is it? Pictures are always helpful too.
Reply 2 of 8, by Benedikt
Nah, it's typically soldered. 😜
Reply 3 of 8, by GodModule
Doornkaat wrote on 2022-10-12, 09:49:
-edit-
oOf3X77
https://imgur.com/a/oOf3X77
I believe it's this one
5GljjHN
https://imgur.com/a/5GljjHN
Reply 5 of 8, by GodModule
vstrakh wrote on 2022-10-12, 18:03:
That's an inductor, not resistor.
Power goes through it, so unless it's feeding some external connector, it's a required component.
Ah right, I'm completely clueless when it comes to PCBs and components. I found another Vogon thread with the same issue
Re: Can someone help me with this damaged Voodoo3 3500TV?
How would one with no soldering abilities go about fixing this? Is there a residential Vogon soldering guru willing to help?
Reply 6 of 8, by Doornkaat
Depending on your location I'm sure somebody is willing to solder the inductor back on.
If you're in Germany I can offer my help for the cost of shipping.
If you're outside of Germany it's probably not worth the cost.
Reply 7 of 8, by Shponglefan
GodModule wrote on 2022-10-12, 18:18:
Your best bet might be to find a local repair shop that specializes in electronic repair that could solder it back on.
It's not a particularly difficult repair, but if you've never done soldering before, trying to resolder an SMD component could cause more issues than not.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 8 of 8, by darry
Shponglefan wrote on 2022-10-12, 19:24:
I did that when a surface mount component fell off a Geforce FX 5900 . It cost me like 15 or 20$.
