First post, by llm
this code is part of a EGA/VGA 320x200x16 color DOS game reverse engineering project - i have no real knowledge about legacy video code stuff except the easy peasy Mode 13h with 256 colors per pixel-byte
does that code change the internal EGA/VGA palett?
// bytes comming from a game picture file
std::vector<uint8_t> color_data{00 05 01 03 00 3A 03 05 38 07 39 3A 3E 3C 04 3F};
// used this way
for(int index = 0; index < color_data.size(); ++i)
cli();
// force index state
inb(0x3DA);
outb(0x3C0, index); // activate cpu-access + color-index
outb(0x3C0, color_data[index]); // color data
inb(0x3DA);
outb(0x3C0, 0x20); // activate video access
sti();
i've found the infos about behavior of port 0x3C0 and 0x3DA here https://github.com/cirosantilli/ralf-brown-in … d/PORTS.B#L4666
the index is the color-index but the data part of 0x3C0 is not fully clear to me
indexed registers in ATC (flipflop set to 'data'): (see #P0662)
Bit(s) Description (Table P0663)
7-6 reserved
5 secondary red video
4 secondary green/intensity video
3 secondary blue/mono video
2 primary red video
1 primary green video
0 primary blue video
Question 1:
what is a secondary blue/mono video bit and a green/intensity video bit?
Question 2:
aren't port 0x3c8(color-index) and 0x3c9(R,G,B) used for color palett changing?
Question 3: could have the code be written like that?
cli();
inb(0x3DA);
sti();
