First post, by Demo85
I'm trying to get another XP machine up and running, while installing the drivers it gets stuck on "Detecting graphics hardware". Tried a few different versions of the driver but it's always stuck on that. I can go and manually install the driver through Device Manager and it works but CCC never gets installed. This is on a fresh install of XP SP3 with only my chipset driver installed. Hoping someone will have a solution to this issue. Does it need some sort of dependency installed for it to work? Like Net Framework or something like that? Thanks
