First post, by Syntho
I have an S3 ViRGE DX card. When in dos everything is fine, but in windows 95 there is a small vertical black area on the left of my monitor where the cursor stops. Conversely the right side of the image is out of view (where the time is). I can adjust my CRT to move the whole screen over to the left and it looks fine then, but then the DOS prompt is too far to the left when I go into DOS.
Is there a setting in W95 to change this? If not there might be some S3 software that can. I remember using a Diamond Stealth card and it had something like that but that was for Diamond Stealth stuff.
