First post, by acl
- Oldbie
Hello
I recently received a Compaq Qvision 2000+ PCI card based on Matrox IS-ATHENA chip.
I tried to test the 3d capabilities of the card under DOS but the card seems not recognized by the applications.
Is there something I'm missing about the setup ?
Env variable ? Found nothing in the documentation.
Extra question : I found a few info about the SCSI connector and it's usage. Some sources seems to believe it's not used. Some that it's a proprietary interface taking the physical forme of a SCSI connector and some sources implying that it can be actually be used (I seriously doubt it). Any ideal ?
Thank you very much!
