First post, by mcmyn
Hey all,
so you know the drill: I recently bought a Voodoo 1 card off eBay, "untested, as is"... and of course it does not (really) work on first attempts.
The first thing I can tell is that passthrough and switching works, but in 3D mode it only outputs a screen full of about 20x20 rectangles in two colors (really, bright and dark variations of one color, which changes between different PCs/PCI ports/attempts).
In playing around with mojo.exe and log files, I see that the FBI memory is detected to be 4mb in size, which seems to me an indication that something is wrong there, right? The thing should have 1 TMU with 2mb and an FBI mem of 2mb, making for 4mb of memory overall, correct?
Does anyone have good tips what I should try to do/look for next?
I do think that one of the corner pins on the FBI chip ("Chuck"? I'm so new to all this...) is suspicious; it might not be firmy attached to the board. Would that cause behaviour like this? It seems like a good next step either way to re-solder it.
Either way, would be happy about resources like diagrams, an orientation for how mojo output/log files *should* look etc.
Best regards!
Reply 1 of 4, by Meatball
That type of output can occur on systems which are too fast, but it can vary from card to card. I have one Voodoo which does the same with speeds faster than 633MHz/66FSB.
Try a slower system and keep the FSB under 100MHz. A Pentium II @ 333MHz/66FSB is ideal, more or less.
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 2 of 4, by mcmyn
Huh, that's exactly the kind of obvious-in-retrospect feedback I came here for, thanks Meatball 😁
I have a Pentium MMX 166 in preparation to be bought and taken home from work, so that fits nicely and I should be able to test the theory soon enough.
Two questions:
1) Any chance it would help to cripple/slow my current CPU (Athlon 1100) down by disabling cache(s), or does that not do what I need because it leaves the FSB untouched?
2) You think the CPU speed problem could also be the culprit in mojo.exe detecting too much FBI memory, or do I more likely just have two separate issues?
Reply 3 of 4, by Meatball
1 - Using slowdown utilities like throttle or Setmui combined With a slower FSB is worth a try. Give it a try no matter what; some cards are luckier than others. For a proper mojo test, I would not rely on the results unless the card was tested at speeds known to work with the Voodoo like your incoming Pentium MMX, for example. Install the card there and see if you can reproduce the problem.
2 - A suspect pin is a concern. You can use an exacto knife to gently apply pressure to determine if it’s loose. Be very gentle, though. But again, I’d validate the card in the MMX 166 machine, first. Unless it is something obvious like pins touching, I’d avoid taking unnecessary risks in damaging the card, however slight.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
Reply 4 of 4, by Imperious
If You can reduce the multiplier to 5 or 6 it may work. My Voodoo 1 failed with the rectangles on screen after 600mhz with an AMD Duron or Athlon, but failed at 500mhz with an Athlon XP Barton,
I think the extra cache had an effect as well.
