Duffman wrote on 2023-05-25, 15:46:I had an issue with a sound card that would not work at all in windows 98 until I did a reinstall of the OS and turned off ACPI. […]
LSS10999 wrote on 2023-05-25, 15:31:
In the end, this probably really looks like some kind of ACPI-related issues with your board on Win9x, but it does not affect WinXP.
@antiriad
I know reinstalling an OS can be a tedious thing, but it'll be worth it if it resolves your issue.
I will make a full partition backup and see if I can reinstall it at a later time.
However, I was able to make some progress and I can now see my Nvidia 7900 recognized after I make the following changes.
1. Disabled ACPI in Windows by Regedit HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Detect\ "ACPIOption 0x00000000 (0)"
2. Disable ACPI in BIOS
3. After reboot goto Control panel/Add New Hardware/Next/Next/NO/Next/System Devices/Next/highlight(standard system devices in the left pane and scroll to Plug in and Play BIOS(fail safe)in the right hand pane and ok it apply it and let the system re-detect your hardware and point it to the correct drivers. Reboot
4. System now sees NVIDIA 7800 and I am able to install the Drivers. (Modified Version)
5. The Second PCI-to-PCI Bridge is still showing some conflicts. The "Motherboard Resources" seems to have resolved it's conflic.
After rebooting the Nvidia 7900 seems to be working but I am experiencing a total system freeze after 30+ seconds.
It seems to reinstall the OS might solve this issue.
I will probably leave this on the back burner for a while since I put a lot of effort into this.
If I manage to get some progress I will port an update.
Thanks, everyone for your valuable advice.
