First post, by Geri
Hi. I have read on wikipedia: there is a beta win2k driver for the Riva128 that supports opengl. Is this true? Anyone has that driver? I was not able to find it anywhere.
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
Reply 1 of 8, by giantclam
Not exactly what it says ...(quote) "A beta driver with OpenGL support was once leaked by Nvidia but was canceled later, and there is no Windows 2000 driver for RIVA 128 on Nvidia's driver site today."
Reply 3 of 8, by progman.exe
This post
https://arstechnica.com/civis/threads/seeking … 8/post-12323702
says
I found a website that is hosting Win2k drivers for the Riva 128 that has an opengl driver included..... The version of the driver is 3.37
This page has a v3.37 for 9x, which may work on 2k. WDM, IIRC?
https://soggi.org/drivers/nvidia.htm
Apparently I have a malicious browser and can't download the file (probably the lying referrer), so can't have a mooch at the driver. The file's size is bigger than the older NT4, which fits with the Ars comment from 2003.
Reply 4 of 8, by Geri
progman.exe wrote on 2023-11-14, 22:52:
Thats the last win98 vxd driver on the link.
Reply 5 of 8, by Geri
I found some other sources. The file was called "riva128(zx)Win2k.zip"
*** Offiziell gibt es von nVidia keinen Windows 2000 Treiber für die Riva 128 (ZX), es gibt nur den von Microsoft bei Windows 2000 mitgelieferten Treiber. Dieser 3.37er Treiber ist also ein Hack und wir wissen derzeit auch nicht, wie gut dieser funktioniert bzw. ob er besser ist als der bei Windows 2000 mitgelieferte Treiber. ***
So basically never tested by anyone, and could be just simply fake
https://alt.3dcenter.org/treiber/grafikkarten-beta.php
No download links in google for such file.
Reply 6 of 8, by Geri
https://forum.nvworld.ru/viewtopic.php?t=9367
"NVIDIA RIVA 128/128ZX Display Driver for Windows 2000 version x.xx, MM/DD/YYYY"
Maybe they just simply extracted it from windows, and put the NT4 opengl driver into the package, and it worked for them.
Reply 7 of 8, by Takedasun
Operating systems supported
Microsoft Windows 2000 Professional
Microsoft Windows 2000 Server
Adapters supported
File list
NV4OGLNT.DLL - RIVA 128/128ZX OpenGL driver
NV4_DISP.DLL - RIVA 128/128ZX display driver
NV4_DISP.INF - Windows 2000 display driver information file for RIVA 128/128ZX
NV4_MINI.SYS - RIVA 128/128ZX miniport driver
README.TXT - The file you're reading
Installation instructions
1. These drivers must be installed by a user with Windows NT Administrator
privileges. Please consult your system administrator or Microsoft
Windows 2000 User's Manual for more information on Administrator
privileges.
2. Start Microsoft Windows 2000.
3. From the Start menu, select Settings.
4. Select Control Panel.
5. Select Display.
6. Select the Settings tab.
7. Select Advanced.
8. Select Adapter.
9. Select Properties.
10. Select Driver.
11. Select Update Driver.
12. Select Next.
13. Select Next.
14. Insert the NVIDIA RIVA 128/128ZX Driver Disk 1 into the 3.5" floppy
drive.
15. Verify that "Floppy disk drives" has a check mark next to it. If it does
not, click in the box next to "Floppy disk drives" to place a check mark
in the box. Select Next.
16. Click in the box next to "Install one of the other drivers" to place a
check mark in the box. Select Next.
17. Select the following driver from the list:
Description Provider Manufacturer Location
NVidia Riva 128/128ZX NVidia NVidia a:\nv_disp.inf
Select Next.
18. Select Finish.
19. Windows 2000 will ask if you wish to restart the computer. Remove any
floppy diskettes from the floppy drive, then select Yes.
Copyright 1999, NVIDIA Corporation. All rights reserved.
    w2k-337_riva128.zip
    469.44 KiB
    38 downloads
