First post, by caiot5
I was wondering why the heck when we're using 256 colors mode in Windows 95 or 98, sometimes the screen refreshes with wrong color palette and then if you open another window / close a program, all of sudden it goes back to normal?
I notice this behavior since my first PC back in the 90s but never found anyone who could answer me this. As retro gurus tribe lurks around this forum, thought it could be a nice place to ask 😉
Reply 1 of 13, by Tiido
Because everything has to share those same 256 colors. These colors however can be redefined and some programs have their own idea what they should that differs from others which makes all the others go crazy as you put it, at least until they come back into focus, then the previous one goes instead 🤣
Reply 2 of 13, by Thandor
Look up ‘VGA color palette’. You’ll see 256 colors like this. If you have a game that is 256 colors but uses more shades of green and less blue you can change (redefine like Tiido said) the palette to incorporate more green at a cost of less blue.
So 256 VGA can basically display more than 256 colors but not all at once.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 3 of 13, by wierd_w
The same is true of EGA palette, but with even fewer colors. EGA IIRC, has a register of 64 colors, that are software definable, of which 16 can be simultaneously displayed.
VGA palettes can be 4 color (for CGA compatibility), 16 color, for EGA compatibility, but also 64 color, 256 color, and pals.
You do not normally see these kinds of palette reprogramming artifacts on EGA, as very few games bother to reprogram the palette. However, the win3x EGA graphics display driver DOES reprogram the palette, (and with some fudging, *CAN* be used with win9x, which DOES make use of the palette reprogramming!! It looks really odd, but It totally works. Win95 on an EGA card is funny as hell, IMO.)
VGA palette was reprogrammed *A LOT* however, because some very interesting video effects can be gained "Cheaply" with just a few bytes written to the palette register. Such as "Fade to black", "Color cycling", and the like. The actual pixel values in memory DO NOT change, but the displayed colors DO, and this can be done very quickly and inexpensively (since memory is not being read or written to), with a wide selection of colors to pick from, with just a few bytes being prodded at the correct IO address for the card to respond to.
EGA was kinda slow on its responses, and even then, there were only 64 colors to pick from (instead of 256), and constraints needed to have nice looking general graphics meant sacrificing some palette space for fancy effects was just too costly in other areas.
Reply 5 of 13, by wbahnassi
EGA colors cannot be software redefinable. The pins on the connector are TTL with 2 bits for each color channel. You can never have anything outside the 64 value combinations possible with 6 bits of data. But yes, you can choose which 16 of those 64 are shown at a time on one screen.
But I wonder why most EGA games stuck to the standard 16-color CGA palette. I even never remember a game from the day that showed colors outside of the standard 16, so I always believed that EGA is 16 fixed colors (and CGA is 4 fixed colors 😅). Any examples of EGA games that redefine the 16 colors to other than the CGA palette?
In fact, Operation Wolf VGA mode is actually using the exact EGA graphics but just redefines the palette to nicer tones than its EGA mode, which stuck to the standard CGA 16 colors. So yeah, both VGA and EGA modes of the game are still 16 colors at a time on the screen.
Reply 6 of 13, by Jo22
wbahnassi wrote on 2024-01-26, 07:34:
Hi, I'm not entirely sure, but I believe that's because this requires 640x350 graphics mode (mode 10h).
And this mode wasn't being used by games so often as it requires an EGA monitor (it has a second set of r/g/b pins, not just R/G/B).
Such EGA monitors weren't used by most home users, though. Instead, they've used a CGA monitor.
A CGA monitor in turn is pretty much like an ordinary TV set with a SCART connector.
Except that the TV has analog RGB (smooth colour levels) and the CGA monitor used TTL (steps of colour levels).
Reply 7 of 13, by Tiido
It is because of the monitors, 200 line mode is fixed to CGA standard and from the monitor itself even though the EGA card could show any of its 64 colors via the output connector, monitor will still treat it as CGA and only listen to 4 of the bits with brown override mechanism. Only in 350 line mode the full 6 bits output is unlocked (or by using VGA, where you can even use the full 18bit capability of the RAMDAC even in any of the EGA modes 🤣).
Reply 9 of 13, by Jo22
Hi, a graphical representation of the classic 256c Windows palette can be seen here:
2.12 KiB
6.78 KiB
It's from a little article of a now defunct website. The article was named The Colors of Windows..
Edit:
Makes sense, and makes me feel even worse about selling our first PC back in the day: A full Samsung XT computer with Samsung EGA monitor. Sigh.
I'm not sure if this uplifting to you, but we all were a bit silly back then and gave things away. You did give it a new home, at least. 😎 👍
Also, you still have the memories and can rightfully say that you had worked with such a classic in first person at the time. 😀
Not all of us here did, after all. I for one did start with a 286 and VGA and had missed out on the XT era.
Reply 10 of 13, by mkarcher
IIRC, the Robot series of games (http://www.tom-games.de/robot/) uses redefined EGA colors. The screen shots show gold bars with distinctively orange pixels. This (100% red, 66% green) is one of the most useful non-standard EGA colors. That game is designed for 350 lines, and supports both Hercules and EGA graphics. It has no CGA support, and thus does not suffer from the limitation that you can't get non-standard colors in 200-line modes.
Reply 11 of 13, by Jo22
^Hi mkarcher, thanks for the info from my side, too! ^^
Speaking of EGA, I vaguely remember reading something about EGA having the ability to display 640x350 mode in reduced colour depth (4c ?) if the installed video RAM was too little.
But I can't exactly remember what this was about. Do you know a bit more about this, by any chance? It's not so important, maybe. It just came to mind right now.
Reply 12 of 13, by mkarcher
Jo22 wrote on 2024-01-26, 13:58:
Yes, I know perfectly what you were talking about. The EGA card internally has a 32-bit memory bus (pedantics might call it 2 sixteen bit memory busses that mostly operate in lock-step). The base version of the original IBM EGA card only had 64K of video RAM, which is organized 16K adresses of 32 bits. In native EGA graphics mode, the EGA card fetches a 32-bit word and generates 8 pixels from those 32 bits of data. If the RAM consists of 16K "words", you can generate 8*16K = 128K pixels from it. 640*350 on the other hand has 224K pixels, so it just won't fit. That's why IBM added an optional second mode to the pixel generation unit: It still fetches 32 bits at a time, but does not just generate 8 pixels from it (using 4 bits each), but generates 16(!) pixels from it, using 2 bits for each pixel. This is good for up to 16*16K = 256K pixels, which is sufficient for 640x350. On the other hand, this is absolutely not the same logic that is used for the CGA-compatible 4-color graphics mode.
Furthermore, in standard EGA graphics modes, 32 bits of video RAM are associated with each address, and programming of the graphics controller and the timing sequencer instruct the EGA card how to associate the 8 ISA bus bits to the 32 video RAM bits (which is a topic you can write a whole book about). This means that in standard 16-color operation, an EGA card with 64K of video RAM only uses the first 16K of that address window. If you select the 640x350 mode on an EGA card with just 64K RAM, the ISA bus interface is swichted into a different mode, though: In that mode, it maps two consecutive ISA addresses to the same location in video RAM, so the video RAM now covers 32K of the address window instead of 16K. At the same time, only 16 bits of the full word width of 32 bits are accessible at each ISA bus location: At even addresses, only bits 0..7 ("plane 0") and 16..23 ("plane 2") are visible (applies under certain conditions), while at odd addresses, only bits 8..15 ("plane 1") and 24..31 ("plane 3") are visible. This mode is called "odd/even" mode for likely obvious reasons. So the 16K x 32 RAM is mapped in a way that it appears to be 32K x 16. Certain kinds of EGA graphics operations work the same in 16-color modes and the high-res 4-color mode, so if you refrain from advanced graphics controller tricks, you might be able to re-use the code meant for 16-color graphics also in 4-color graphics mode. Because of the way the mapping is performed, the 4-color mode looks like only colors numbered 0,1,4 and 5 exist.
Reply 13 of 13, by Jo22
Thank you very much for the explanation! It's well done, btw. I've always wondered what this was about! 😁
