First post, by theelf
- Oldbie
HI, greetings i have a AGP S3 Trio 3D (NO 3D/2x)
My problem is in this card 320x240 mode work at 73hz no 60hz, for example in DOS if in a emulator, i select vesa1 or 2, 320x240 work at 73hz, but mode-x 320x240 is 60hz, same happen if i load scitech vesa, now vesa 1-3 320x240 modes are 60hz..... maybe because modex/SDD dont read resolution info directly from bios?
In windows 95 using S3 drivers happen same, 320x240 mode is at 73hz, but is not the driver, because i installed windows 2000, and using default microsoft s3 driver, happen same with 320x240 mode
My question is if someone have a AGP Trio 3D (no 3d/2x) to test, to know if is just my card, or all trio3d cards have same problem
thanks a lot
