First post, by rain
Hi , icant find 3dtools for my banshee card anyone knows where to download
Reply 2 of 8, by rain
Tried to install standalone installer now getting this error when entering display properties
Problem about. " desk.cpl "
Reply 4 of 8, by eddman
No idea why the tool doesn't work with the ref driver, but someone back then combined the two in one package and it works.
https://www.oocities.org/bansheedrivers/page3.html
https://www.guru3d.com/download/3dfx-ba ... -win9x|me/
Run setup.exe to install the tool but after that you might have to install the driver manually from device manager.
Reply 5 of 8, by rain
eddman wrote on 2024-04-14, 11:40:
No idea why the tool doesn't work with the ref driver, but someone back then combined the two in one package and it works. […]
No luck , same error "desk.cpl"
Reply 7 of 8, by rain
eddman wrote on 2024-04-14, 12:19:
It works here. I don't think it'd work after you've already installed other 3dfx stuff. Try a clean install.
Clean windows98 install fix it. But im curious why official drivers not work..
Reply 8 of 8, by eddman
Actually, 3dfx tools are intended for V3 and higher, so the problem with the ref banshee driver is probably normal.
Banshee drivers do have their own simpler, built-in control panel but for some unknown reason it simply doesn't work in driver 1.04. Previous versions do.
