First post, by RobDos
I got this board that seems to work in dos with minimal testing (ran doom quite nicely)
I tried to load Windows and I got not enough memory, even in safe mode. Suspect this is due to the shared video memory not being properly reserved in DOS?
The processor is a Dual Core Atom 330 with the Intel 945GC Express Chipset and ICH7 hub, Intel GMA 950 with Svideo out and Relatek ALC662 audo codec.
I tried both unisound and dossound and neither recognized the card, unisound said no pnp cards present and dossound said HD audio chipsets not supported.
The next issue I ran into was univbe (that I had) didn't recognize the card and VBE apps wouldn't load.
I was hoping this board was old enough to be tricked into running a basic dos system, i might be able to FIX one issue with the single PCI slot but certainly can't fix sound, video and memory.
Before I give up I hope that someone within the vogsphere can help, perhaps Zarniwoop can help?
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
