First post, by DamienC
I have copies of both Descent 1 and 2 and I want to get into them. What's a good control scheme to use for this game?
I've tried just KB+M with WASD for vertical and horizontal movement. It's somewhat usable but the mouse isn't sensitive enough for my liking even with the sensitivity cranked. I've heard people say that using KB + a joystick is a great way to play.
Do any of you have a recommendation for a good control setup? I'm playing on real hardware, not DOSBox if that matters. I have a couple joysticks and a Gravis Gamepad.
Reply 1 of 13, by Hoping
Joystick with hat for slide and two buttons for forward and backward, that was my way of playing six degrees of freedom games for years, Descent 1,Descent 2,Descent 3,Forsaken and Overload.
Reply 2 of 13, by AirIntake
I use a "KB+J" control scheme for Descent where I used WASD like in a normal FPS for forward/backward/slideleft/slideright but instead of the mouse I use a SideWinder 3D Pro joystick to control "look" of yaw, pitch, and roll. I use inverted Y axis so it's normal aircraft controls and the hatswitch controls up/down/left/right sliding (though left/right is redundant because that's what A/D also do).
Casio BE-300 Advancement Society alumni
Reply 3 of 13, by Pierre32
AirIntake wrote on 2022-02-06, 20:35:
This is my optimal setup too. Basically standard KB+M FPS scheme with the joystick replacing the mouse. Q+E for roll. Bonus if the Joystick has a couple of extra buttons for slide up/down, but otherwise I have those mapped to left shift & ctrl.
I also have my arrow keys mapped to pitch & yaw as a stand-in for the joystick if it's not connected. I actually play this way a lot.
Reply 4 of 13, by AirIntake
Pierre32 wrote on 2022-02-06, 20:55:
Ha ha yeah I do this as well. Mostly for testing but it does feel good enough for extended play.
Reply 6 of 13, by Pierre32
dr_st wrote on 2022-02-06, 21:46:
38Marvin38 is a keyboard-only player that can beat the game on Insane difficulty. He posted his control setup here:
https://www.youtube.com/watch?v=Tk_EKluatPM&l … NWps7-Jjweg4x9Q
A few interesting differences to my mapping. I might give that a go.
slide up: num1 slide down: num0 drop bomb: right control fire primary: left shift fire secondary: space flare: x automap: tab re […]
slide up: num1
slide down: num0
flare: x
automap: tab
rear view: r
Reply 7 of 13, by The Serpent Rider
Never understood flight-sim joysticks in Descent-like games. They are poorly optimized for those, due to lack of constant velocity and twitch-shooter nature of gameplay.
That's because it was intended design, similar to how Dead Space 1 controls were "floaty". Joystick won't help it in any way and may do more harm to controls, due to added physical limitations of such device. I think some source port probably "fixed" that already, by adding instant FPS-like input.
Reply 8 of 13, by Pierre32
The problem I have with a mouse in this game is the lack of absolute positioning. If you want to turn 180 degrees it's a few drags of the mouse, vs just holding the stick in one position - like you would do with a flying craft.
But I'll concede that a big stick can be pretty unweildy for Descent. For that reason I've always wanted a compact one, maybe even something you could cup your hand over like a big trackball (but it tilts on axes, doesn't spin). I've never come across anything like that. [edit] Well, there's the Spaceball if you can find the right model and get it working.
Reply 9 of 13, by The Serpent Rider
Modern Xbox/PS gamepad works quite well with Descent.
Reply 10 of 13, by Pierre32
Not in DOS 😁 Why make things easy for myself?
Reply 11 of 13, by maxtherabbit
The Serpent Rider wrote on 2022-02-07, 04:23:
this, after playing the original xbox source port nothing else compares
Reply 12 of 13, by fuchal
I use WASD for slide and acceleration and arrow keys for pitch. I find it works pretty well and is pretty easy to control.
Reply 13 of 13, by Ringding
I used the 6-key block on a PC keyboard with the left hand as the cursor cross + 2 keys for up/down. For looking, I used an analog joystick. And for rolling, I extended the left hand’s thumb and used the 0 key on the numeric block for rolling right and the right cursor key for rolling left.
